Velocity Speed Shop
Pinion Angle
Does anyone know about correcting the pinion angle an a 69' truck lowered 4" in the rear with just 4" drop coils and lowered shocks? Do I even need to worry about it since it's only going to be lowered 4"?
Re: Pinion Angle
I've got 2.5" up front and 4" drop coils in the rear, I even heated them a little more and I would'nt worry about the pinion angle. There aren't any issues that you'll run into except for the carrier bearing will fail, at that point I would switch to a one piece drive line. That's what I had to do.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
Prestige Worldwide
![]() Join Date: Feb 2001
Re: Pinion Angle
The guys at Early Classic told me once before that you can go up to a 6" drop on a truck with a coil spring rear before pinion angle becomes a concern....
Re: Pinion Angle
Yeah... 6" sounds about right. I always figured if I went far enough to require a c-notch then I would mess with the rear end...
