Old 04-26-2008, 09:10 AM   #1
flat68
Lowering Blocks
Would there be a market for 6061 aluminum predrilled lowering blocks out there??? let me know guys. would build to suit as far as thickness goes. If so what would they be worth?
flat68 is offline   Reply With Quote
Old 04-26-2008, 09:16 AM   #2
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: Lowering Blocks
I think you would have a Market for them , More so if you made the u-bolt's available with them.............
I would do some research on what a kit like this Goes for to see what you may have to charge, That would be Your Best way of Knowing if it's Going to be Worth your Time.
Alum. Price is High at The Moment, Guess you got to factor that in Also............
Good Luck with the Project.
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 04-26-2008, 01:49 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: Lowering Blocks
Most places sell the complete kit with hardware for $69. I remember seeing on online place making custom sized U-bolts for about $10 each plus shipping but I'd have to find the link. I thought about having the bolts made and then making my own blocks but never got around to it. I'll be following this thread to see what you come up with.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-26-2008, 06:33 PM   #4
flat68
Re: Lowering Blocks
Yes i could supply the u bolts as well if needed.. the blocks i built for mine are 1" and my new u bolts were long enough. over 1" and longer would be required.
Old 04-26-2008, 06:45 PM   #5
Super-Dave
Super-Dave's Avatar
Re: Lowering Blocks
Here is a link to a supplier, but he only has 1.5" right now, said he dont know when he will get anything else back in. I would buy a 2". I got my bolts made locally for 2" and got the 1.5" just to get it done for right now.
http://www.stockcarproducts.com/trkarm1.htm
Super-Dave is offline   Reply With Quote
Old 04-26-2008, 10:05 PM   #6
Shane
Shane's Avatar
Re: Lowering Blocks
The aluminum (6061 T-6) for a solid block is gonna cost more than most here are willing to pay. Already been down this road. Not meaning to sound like a know-it-all, just passing on some friendly advice.
Shane is offline   Reply With Quote
Old 04-26-2008, 10:33 PM   #7
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Lowering Blocks
Autozone sells 2 in. for 27.99 and 3 in. for 34.99.
Its not aluminum, but it works for me.
Born with a Bowtie
1971 C/10 350/350 Daily Driver/project
Assumption=The mother of all -ups
Highsteel is offline   Reply With Quote
Old 04-26-2008, 10:37 PM   #8
c10crazy
Like a Rock!
c10crazy's Avatar
Re: Lowering Blocks
With hardware??? Do you have the part number for the kit?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 04-26-2008, 10:48 PM   #9
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Lowering Blocks
They are available as a kit, distributed by Superior Automotive, including blocks, U-bolts and nuts.
The numbers are as follows:
1" kit - 13-1000 - 24.99
2" kit - 13-1030 - 27.99
3" kit - 13-1040 - 34.99
Born with a Bowtie
Old 04-26-2008, 11:43 PM   #10
Super-Dave
Super-Dave's Avatar
Re: Lowering Blocks
Are those for leaf or coil trucks?
Old 04-27-2008, 12:42 AM   #11
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Lowering Blocks
Uhm, yes.
I believe they work for both. If the axle is below the leafs its a 'lift' kit, if the axle is above the trailing arms its a lowering kit.
Born with a Bowtie
Old 04-27-2008, 02:15 AM   #12
Shane
Shane's Avatar
Re: Lowering Blocks
those listed above from AutoZone won't work on 67-72 trucks ... here are what lowering blocks for a trailing arm suspension look like ... notice there are only 2 U-Bolts .. not 4.
Old 04-27-2008, 02:42 AM   #13
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Lowering Blocks
Hmm, do you suppose those kits use smaller bolts?
I'll have to run down there and take a closer look.
Born with a Bowtie
Old 04-27-2008, 05:33 AM   #14
Shane
Shane's Avatar
Re: Lowering Blocks
they don't mount any where close to the same highsteel ... they won't work on our trucks ... the ones you link to are basically made for mini-trucks and other small / narrow leaf spring applications.
Old 04-27-2008, 06:35 AM   #15
flat68
Re: Lowering Blocks
Would roughly 60-70$ a set be out of line for aluminum blocks?? I'll have to check on my pricing for bigger aluminum. May be a little more for over 1". Just really liked the look of the aluminums i built for mine. thats why i started this thread
Old 04-27-2008, 06:38 AM   #16
flat68
Re: Lowering Blocks
I forgot to add that i may look into custom blocks w/ pinion angle correction machined into the blocks for a clean look w/out having to stack shims w/ blocks.
Old 04-27-2008, 05:54 PM   #17
flat68
Re: Lowering Blocks
what do you think fellas?
Old 04-27-2008, 07:13 PM   #18
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Lowering Blocks
OK. Sorry
Born with a Bowtie
Old 04-27-2008, 07:17 PM   #19
toomanytoyz
Luv the Crewcabs
Re: Lowering Blocks
Would be Nice if you were to post some Pics of what you have.............
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 04-27-2008, 07:31 PM   #20
SCOTI
SCOTI's Avatar
Re: Lowering Blocks
People already buy the alum blocks that CPP sells so there is a market.
To be competitive, you'll have to beat CPP's prices, quality, or offer something as an advantage. Pinion adjustment would be an advantage if it were incorporated into the manufacture of the blocks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-28-2008, 12:46 AM   #21
loef
loef's Avatar
Re: Lowering Blocks
I got my springs and alu blocks with u bolds from Truckshop. But the package said CPP.
loef is offline   Reply With Quote
Old 04-28-2008, 04:31 AM   #22
flat68
Re: Lowering Blocks
How much is cpp charging for theirs? and what aree they including in the kit? Or is it just pre-drilled blocks???
Old 04-28-2008, 04:34 AM   #23
suville
suville's Avatar
Re: Lowering Blocks
Is that rear brake line copper??????
suville is offline   Reply With Quote
Old 04-28-2008, 04:39 AM   #24
70c10
67-72 Addict!
70c10's Avatar
Re: Lowering Blocks
I think $69 including all hardware, bolts,etc. Your choice of 1", 1.5" or 2" I believe.
Jim
Old 04-28-2008, 01:01 PM   #25
loef
loef's Avatar
Re: Lowering Blocks
69,- is exacly what i paid for it from Truckshop.
You are right. I made all brakelines from copper-nickel. Its easy to bend, and you can make the double flare yourself with a special tool.
