Old 04-26-2008, 06:30 PM   #1
buffle
buffle
buffle's Avatar
400th kickdown
Trying to find kickdown parts for a "72". Right now I don`t have tranny hook-up or kickdown solenoid.
buffle is offline   Reply With Quote
Old 04-27-2008, 02:17 AM   #2
JimKshortstep4x4
Re: 400th kickdown
Are you looking for the wiring harness and transmission detent switch for a TH 400? Normally the detent switch is in the transmission. I may have the wiring but not the detent switch. Can you clarify as to what you are looking for?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-27-2008, 03:07 AM   #3
Classic Bowties
Always on the hunt...
Re: 400th kickdown
I think that he is looking for the pedal mounted switch and wire harness that goes from this switch down to the trans. This one pictured is off a 71 but will work on a 72 or vise-versa. Good luck on your hunt!
Classic Bowties is offline   Reply With Quote
Old 04-27-2008, 05:34 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 400th kickdown
that is in fact the correct set up for 71 and up (till the 90's)
Old 04-27-2008, 05:51 AM   #5
Old Money
Re: 400th kickdown
early 70s big GM sleds pontiac buick and olds big blocks had same setup. i found mine on a 73 olds 98. my 72 had original goofy temp sender on passeger head and warmup soleniod under dash . i bypassed this stuff and made it work like 71 did. silly g.m. answer to govt. control .
Old Money is offline   Reply With Quote
Old 04-27-2008, 06:09 PM   #6
buffle
buffle
buffle's Avatar
Re: 400th kickdown
Yup that`s what I need, to be honest i didn`t know what it looked like. thanx for the help, I will see what I can find.
Old 04-28-2008, 06:08 AM   #7
STP67-72
STP67-72's Avatar
Re: 400th kickdown
Shanes Chevys had one yesterday at Pate swapmeet. Try to PM him.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 04-28-2008, 03:32 PM   #8
buffle
buffle
buffle's Avatar
Re: 400th kickdown
Shanes Chevys doesn`t work. Anyone know his PM address?
Old 07-23-2008, 03:09 PM   #9
lyrikz
PITbut
lyrikz's Avatar
Re: 400th kickdown
LM, if i had a setup off a 81 chevy 2wd truck (where i got the transmission from) would that work on my 71 truck?
lyrikz is offline   Reply With Quote
Old 07-23-2008, 04:06 PM   #10
Longhorn Man
Re: 400th kickdown
the switch should be correct... I dunno about the pedal bracket and stuff though.
Old 07-23-2008, 04:20 PM   #11
lyrikz
PITbut
lyrikz's Avatar
Re: 400th kickdown
I kept the donor truck until my truck was done just for this reason. I will inspect everything and see what i can use and what not..
Now that i know how that kickdown works, any ideas how the electric choke would work in my 71?
