Old 04-26-2008, 06:38 PM   #1
96blazr
96blazr's Avatar
brakes
Howdy everyone.
I own a 1968 C10, it's a 350/350 truck with Power assisted Drum Brakes all around. I'm getting ready to do a brake job and need to know what size brakes I have.
I was on the trusty LMC site and it says I'll either have 11" or 11 5/32". Short of taking a wheel off and getting the old tape out, is there anyway to know?
Mine is a 1/2 ton, so does that make any difference?
Any help will be greatly apperciated.
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 04-26-2008, 07:10 PM   #2
Sammy
Re: brakes
Not for sure but you could probally measure the outside of the depth of the drum as they had two size drums also. Cross reference the drum back to determine the size brake shoe.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-26-2008, 07:15 PM   #3
Sammy
Re: brakes
I think most were the smaller shoe. The larger one must have been heavy duty an option on the glove box SPID maybe??
Old 04-26-2008, 08:28 PM   #4
96blazr
96blazr's Avatar
Re: brakes
Thanks Sammy. Guess I'll just have to take a wheel off then. Would rather not till I have to do the job itself, but what the hell.
1968 SWB.
There you are.
Gary
Old 04-27-2008, 02:19 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: brakes
you aren't buying your brake parts from LMC are you?
I'm 99% positive the smaller one is the norm with the exception of the suburbans and panels.
Old 04-27-2008, 06:18 AM   #6
cdowns
cdowns's Avatar
Re: brakes
i'd say take the drum off to measure them and while you're in there look and see if any of those 40year old parts need replacement and also check to see if the drums are good and can still be used//all parts should be readily available at your local parts store
