Post pics of X-pipe exhaust setups...
I know that there have been many discussions and pics of X-pipes, but searching the archives have not turned up what i am looking for.
I am finally getting to add new exhaust to my truck and i was wanting to see how the rest of you have routed your exhaust with an X-pipe incorporated. |
Post Whore
![]() Join Date: Feb 2000
Re: Post pics of X-pipe exhaust setups...
Here is the system in my 69 K20 with a swapped in bbc.
The system is 3" pipe from the headers to the x-pipe, then 2 1/2" to Dynomax UltraFlo's and continues as 2 1/2" pipe dumping at the rear of the flatbed angled down slightly. Here are some pics of the system. This is the X-pipe that I had built by someone I found on E-bay. ![]() Rather than use the collector piece that came with the headers, American Muffler made their own piece ![]() The passenger side collector was fairly close to the transfer case. Here is a pic of the pipe coming over the transfer case ![]() ![]() Here is the X-pipe installed directly behind the transfer case ![]() ![]() ![]() And here is an example of the welds at the X-pipe ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Post Whore
Here are the Dynomax UltraFlo mufflers
![]() Pretty straight shot to the rear of the truck ![]() The pipes dumb right before the hitch and are well protected ![]()
Chasin' the Dream
What is that about a three inch body lift? that makes running exhaust a breeze!
Born with a Bowtie ![]() 1971 C/10 350/350 Daily Driver/project Assumption=The mother of all ![]() |
Nice set up, I'm a fan of the cross over system myself.
yes the lift helps out.
that is pretty much how i want to run mine, but its going to be alittle trickier. i plan on cutting through my trailing arm cross member and then reinforcing with 4" pipe. I want them to end like yours, minus the turn down. I haven't picked a muffler yet, but i want to tone it down some. i am running cherry bombs now...with a hole in the H-pipe. |
