04-27-2008, 01:38 AM | #1 |
Dr. Frankentruck's Monster
Invisible Wiring Harnesses
Hey everyone. I'm trying to get some ideas to make my engine compartment completely devoid of of visible wiring. I don't know if that is entirely possible, but the cleaner the better.
If you have attempted such a feat, would you be willing to share the results of your endeavor? Thanks everyone! Mike
I'm not prejudiced, I hate everyone. Project SLOMO http://67-72chevytrucks.com/vboard/s...d.php?t=430494 |
04-27-2008, 01:50 AM | #2 |
Re: Invisible Wiring Harnesses
*Subscribed*
Joe |
04-27-2008, 11:05 AM | #3 |
ttt
04-27-2008, 11:50 AM | #4 |
Here's a little info from a previous thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=279708
Joe |
04-27-2008, 05:03 PM | #5 |
Good idea
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
04-27-2008, 06:09 PM | #6 |
.....I am working on it.....
Another thing you can do is hide it in a metal "conduit" then paint it to match. You can use 3/16"-1/2" brake line tubing. Form it to whatever surface its mounted. Of corse this wont work with all of the factory harness ends, but if you are going custom, its an option.
04-29-2008, 03:03 AM | #7 |
Too many projects
I have an almost no-show wiring harness. It routes out the bottom of the cab on the passenger side to the frame rail, runs forward on the rail to the rad support and then up onto the support. Any exposed areas are pulled through rubber fuel line (5/16") or heater hose (starter 5/8"). The wires for the carb, air pump, and temp sender come up the back of the motor and route along the inner valve cover also in fuel line.
No pics at the moment, she's torn up right now...
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
04-29-2008, 03:04 AM | #8 |
Too many projects
I also have a custom harness with the fuse box in the former glove box/heater area.
04-30-2008, 01:42 AM | #9 | |
