Old 04-27-2008, 02:40 AM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Radiator Suppor AC lines....Question
Can someone please measure the position of the hole in the radiator support. My support doesn't have the hole so I need to make one.
Sorry the picture is so small. I could not attach a larger one. See pic below. Thanks
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 04-27-2008, 02:58 AM   #2
john
member #16
john's Avatar
Re: Radiator Suppor AC lines....Question
If you look closely , there is a dimple in the support where the hole is to be drilled. There are also dimples where the dryer clamp screws go.
john is offline   Reply With Quote
Old 04-27-2008, 04:15 AM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
I think I have found which one your talking about and marked it in this picture. Is this the right hole? Any Idea what size the hole is?
Old 04-27-2008, 05:11 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
The hole you pointed out is for the front maker lights wire to pass through
Here is the right hole.
It's about a 1-1.5" hole.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-27-2008, 06:01 AM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
Perfect. I guess I will have to remove the grill so I can drill a hole.
