04-27-2008, 03:17 AM | #1 |
Got big-block?
'72 K2500 with 454/t350/NP205...swap in a 4L80e?
My first 67-72 4x4...new to the 4x4 world...going to use this truck for towing, and would like to swap in a 4L80e behind the 454 in place of the t350. Would like to hear from you guys...since the 4L80 is an electric t400, will it bolt right to the NP205? need an adapter? I know there will be a length difference, so driveshafts will have to be shortened/lengthened?
Thanks for any help, SC.
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
04-27-2008, 03:41 AM | #2 |
Re: '72 K2500 with 454/t350/NP205...swap in a 4L80e?
th350 is worlds better than the 4l80e. If it were me I'd stick a gearvendor on you're th350. More reliable peroid.
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules Last edited by milled; 04-27-2008 at 03:42 AM. |
04-27-2008, 04:08 AM | #3 |
Got big-block?
Thanks, but I'll stick with the 4L80e...I've never had a problem with one in any of the late model 3/4 tons I've had. SC
04-27-2008, 04:38 AM | #4 |
04-28-2008, 06:08 AM | #5 | |
Just did this in my Blazer. You will have to change the input gear on the 205 to 32 spline which will require machining the case for the larger bearing. There is a factory adapter but goo luck finding one. bite the bullet and by a T-case adapter from Advance Adapters, or buy their whole kit. The conversion money wise is not for the faint heart. Figure $3k minimum to buy the parts and get everything installed and modified. Even with me doing all the work myself, including the 205 machine work and overhauling the 4L80E, I have $600 in the 205 conversion parts, $300 for tranny parts, $200 converter, $600 in the stand along tranny controller, $500 for new driveshafts. Cost does not include 205 which came out of the truck or the tranny which the core I got for free from a friend. If you have to pay for the tranny overhaul and 205 rework add another $1200-$1500 on top.
Mike Redpath |
04-28-2008, 06:26 AM | #6 |
How about finding a NP241 from the last Blazers and Suburbans.On a`91 K3500 CrewCab with a 4L80E,did they use the NP205?
04-28-2008, 02:59 PM | #7 |
04-28-2008, 03:03 PM | #8 |
Thanks,I know I hadn`t seen any 205s that late.
04-28-2008, 08:18 PM | #9 |
There were 4l80e/205 combos available in 1991 only. Pretty rare. But, they do exist. EDIT: I think another reason why they are so rare in this year was that they were optional...but this is just my personal guess. I have seen '91s with the TH400, also, which is why I say this.
However, I agree Tim...using a pass. drop NP241 would probably be the way to go in this case. If you ever end up offroading this truck, then just put a good skidplate under the 241. This will be easier to find, and cheaper.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 04-28-2008 at 08:20 PM. |
04-28-2008, 09:21 PM | #10 |
04-30-2008, 04:18 AM | #11 | |
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules |
04-30-2008, 05:15 AM | #12 |
05-02-2008, 07:22 AM | #13 |
It will with a rebuild and quality clutch packs. Go to any track on any given sunday you'll see th350's pulling 10sec (500-600hp). The gm od trannies are problematic to say the least. If you're shooting for the best in class nothing beats the TH400 and $2500 real overdirve. Not only that but you can split the gears. For towing their's nothing better.
05-02-2008, 03:00 PM | #14 |
05-02-2008, 04:20 PM | #15 | |
05-02-2008, 09:25 PM | #16 |
This is the place for the 4l80e guys- nice kit!
#K80. Fits all Chevy 4L80E transmissions. This is the level 3 Quadzilla kit with a converter upgrade. You get all 3 Alto Red Eagle Power Packs for 1st, 2nd and 3rd, Blue Plats Special clutches and steels for overdrive and the overrun clutches plus a Transgo stage 3 Quadzilla Shift Kit. In addition you get a filter, 34 element sprag, gasket and seal kit, oversize black Kevlar band and the #6XX torque converter rated at 1200 horse power. All of this for $1722.00. YOU SAVE $149.00 HERE !, 8% OFF (Deduct $921.00 without the torque converter.) Acouple of problems he listed should be addressed #2V. Common problems in vehicles with a 4L80-E transmission include uncontrollable line rise (upwards of 500 psi), high line pressure in reverse, broken direct clutch drums and/or broken cases. These problems can be caused by excessive EPC torque signal pressure. The Sonnax self-regulating reverse boost valve eliminates these problems by limiting EPC pressure. The boost valve has an encapsulated relief valve that will allow EPC pressure to exhaust if it exceeds 95-105 psi. A closely toleranced sleeve is included with the kit. This restores the hydraulic integrity between the valve and sleeve, which can also cause the problems mentioned previously. O-rings have been added to the sleeve to compensate for pump bore wear and prevent pump scrappage. Cost $51.00 4L80E Actuator Feed Limit Valve Kit • Kit includes wear-resistant sleeve and anodized valve with annular grooves to prevent side loading. • Valve operates in full-contact sleeve, providing 54% more support. • Boosts oil pressure to the shift solenoids. • Eliminates AFL oil loss, corrects low line pressure LINK http://www.transmissioncenter.net
05-05-2008, 03:33 AM | #17 |
10-25-2008, 07:28 PM | #18 |
So it is possible to put a 4l60 in place of my 1970 th30, but the package is longer.
So what if i com by moving the motor forward with 1/4" or thicker plates to off set the motor mounts? |
10-25-2008, 07:56 PM | #19 | |
I built it
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
10-27-2008, 05:52 PM | #20 |
6>8 Plugless........
It is all in what you want and how you are going to use it. I will say one thing. I am more into the diesel side, and the TH400, TH350, will not stand the torque of a diesel. Unless you spend gobbs of money on them and replace everything 2-3 times besides the case. With that being said, there are guys that have 4L80E's behind 600hp 1150+ ft lbs of torque 5.9 cummins diesels and the transmission's biggest upgrades are: torque convertor, top quality clutches, valve body up grade. And they actually live behind the diesel and you aren't removing the trans every other month like you would be with a TH400 or Th350. The TH trannys can take a lot either way in a gasser, but the biggest down fall to them is when you have to spend $2500 or more to get a secondary OD unit on top of your transmission build. So if this guy knows he is going to tow a lot and wants an OD and is limited on wheel base, I think he has the right idea. Sorry for hijacking your thread. LOL
