04-27-2008, 04:14 AM | #1 |
5 lug changeover
I'm new and don't know much about changing things around on my 68 shortbed. Whats the best way to go to 5 lugs on the rear? someone sold me another rearend that they said came out of a truck but none of the brackets are the same and i don't see how it could work. can i swap out the axle's or should i just get a kit for that or try and find a rearend that does look like mine. mine only has the saddles that sit on th
04-27-2008, 04:47 AM | #2 |
Re: 5 lug changeover
I just installed the 5 lug axle swap kit from performance online and it was very easy. It wasn't too expensive, and was simple to install.
04-27-2008, 04:53 AM | #3 |
Go to moser axles websight. Your better off buying new axles.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-27-2008, 05:54 AM | #4 |
Your best bet for a budget is to find an 71 72 truck and swap everything over. Which is not a hard task pretty much a bolt in.I know where everything you need is. rearend ,all the front pieces. I believe he told me 200 for everything. I thinking Danville isn't that far from me.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 04-27-2008 at 05:55 AM. |
04-27-2008, 06:02 AM | #5 | |
Joe |
