factory springs
does anybody have any advice on how to take the factory springs off of the rear of a 71c10? it took me and my dad about 3 hours with a breakerbar just to do one side and now im stuck like this over night lol so i figured before i attempt the otherside in the mornin i would ask here.
91 gmc k1500 chevy grill power buckets 350 5 speed |
67-72 Addict!
Re: factory springs
Do you know anybody with air tools?. I would spray the bolts ahead of time to penetrate the rust!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
![]() Join Date: Apr 2008
Re: factory springs
in wi. wehave alot of rust so reusing the bolts and nuts isnt worth it. i used a grinder and ground off most of the nuts till i could tap them gently with a3 lb. hammer once or twice and they would fall right off. the grinder also works with axle u bolts. or a really big cheater bar ,a large bowl of wheaties and ajock strap so the wrong items dont break loose. murphys law. Old money.
Trucks N Tranzams
Re: factory springs
If they are not rusted too badly, oil them with penetrating oil ahead of time and clean the threads up with a wire brush. Go slowly working them back and forth and use lots of oil. They are definitely not easy.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
Re: factory springs
yea tell me about it lol they aint rusted to the point where i cant reuse them but the top one expicaly is a real pain to get to and out air ratchet isnt strong enough to really get them loose
![]() Join Date: Sep 2007
Re: factory springs
I had to weld the nut to the coil clamp on mine and twist the bolts until they broke off. new clamps and bolts are 20$ for the kit. well worth it
![]() Join Date: Oct 2007
Re: factory springs
Just did mine yesterday. Let a rust penitrant sit on them for a while than used a 1/2" ratchet and a 1/2 breaker bar. I put the ratchet with a standard socket on the top and used the breaker bar with a deep socket fit into the spring. Held the ratchet steady and ratcheted the breaker bar back and forth. Worked really good.
GEARHEAD
Re: factory springs
Cutting torch. Buy new bolts. How much is 3 hours of your time worth?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
I am a Referee of life.
Re: factory springs
I used penetrating oil(PB Blaster not WD40), a wire brush and a wrench and long arm breaker bar.The breaker bar was the right tool since i broke them to get them off.Use a die grinder to cut the nut and buy new.It's suspension don't cheap out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: factory springs
yea i would cut the bolts but i just lost my job n i dont have any money to spent really
#11 | |
Re: factory springs
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Re: factory springs
if they were in that bad of shape i would go and find some way to get the money but their really not in bad shape just got enough surface rust on them to make it a pain in the arss
