04-27-2008, 11:23 AM | #1 |
c notch question
I'am thinking of doing a 3 1/2 front drop and a 6 inch rear drop , do i need to do a c notch?
04-27-2008, 06:08 PM | #2 |
Re: c notch question
yes. it would be best to put one in
04-27-2008, 07:28 PM | #3 |
50% here will say a c-notch was not required for their 6" drop; the other 50% will tell you one was needed on theirs.
Be smart. Plan for & install one while you're in there doing the work.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-27-2008 at 07:28 PM. |
04-27-2008, 08:34 PM | #4 |
Ya i e-mailed one of the suppliers with the same question, and was told that i would only gain an inch of clearance before the rear end smacked the bottom of the box. I guess i have to look at it when i get the suspension changed over, and the drop installed . The only thing the truck will hauling will be my @$$,and the occasional case of beer or two. Thanks guys
