Old 04-27-2008, 11:01 PM   #1
andys70c10
flywheel
I am converting my truck from a 3 spd. manual to a th350, my ? is this do I need to change my flywheel? & if so what size, # of teeth do I use? truck has a crate 350.
andys70c10 is offline   Reply With Quote
Old 04-27-2008, 11:09 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: flywheel
You'll need a flexplate to replace your flywheel. Sorry don't know the size offhand, someone will chime in I'm sure...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-27-2008, 11:26 PM   #3
andys70c10
Re: flywheel
will this work?http://www.partsamerica.com/ProductD...pe=267&PTSet=A
Old 04-28-2008, 12:33 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
Re: flywheel
Not a flywheel. With an auto tranny you need a flexplate: http://store.summitracing.com/egnsea...=KeywordSearch
Beat it to fit,
Old 04-28-2008, 01:02 AM   #5
70GMCer
70GMCer's Avatar
Re: flywheel
count the number of teeth on your flywheel and that will be the number of teeth you'll need for your flexplate.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-28-2008, 05:48 AM   #6
andys70c10
Re: flywheel
ok I think I understand, also will I be able to reuse my old starter?
Old 04-28-2008, 07:58 AM   #7
wzuke
wzuke's Avatar
Re: flywheel
Yes, make sure you get the correct flexplate.
wzuke is offline   Reply With Quote
Old 04-28-2008, 01:52 PM   #8
70GMCer
70GMCer's Avatar
Re: flywheel
Yes, if you use the correct numbered teeth as stated above.
1997 GMC Sierra Ext
1965 Mustang
Old 04-28-2008, 03:07 PM   #9
JimKshortstep4x4
Re: flywheel
Since the stick has a bell housing where the starter bolts up with three bolts to the bell housing, a different starter will be needed. On the automatics the starter bolts to the block using two bolts. You will want the starter to match the flex plate.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-29-2008, 06:55 AM   #10
wzuke
wzuke's Avatar
Re: flywheel
Jim
Not!!
Old 04-29-2008, 07:24 AM   #11
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: flywheel
Not!!
What do you mean NOT? He's exactly right. The starters are different between a 3 speed manual and TH350.
You will need a 168 tooth 14" flexplate and matching starter. Just get the parts store to look up a stater for your model truck with a TH350 and you'll be good to go.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-29-2008, 08:10 AM   #12
jsbgump
Gone Fishing
jsbgump's Avatar
Re: flywheel
168 tooth flywheel. depending on your power rating I might even order an SFI approved one
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 04-29-2008, 02:19 PM   #13
70GMCer
70GMCer's Avatar
Re: flywheel
Forgot about the starter being a stick. Yes an auto starter will be needed. Either way, just match the starter bendix head for either a 168 tooth one or the 153 tooth one.
1997 GMC Sierra Ext
1965 Mustang
Old 04-29-2008, 05:20 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
Re: flywheel
Flexplate, not a flywheel for an automatic...
Beat it to fit,
Old 04-29-2008, 07:54 PM   #15
andys70c10
Re: flywheel
yes this http://www.partsamerica.com/ProductD...pe=267&PTSet=A is listed as a flywheel but looks the same as a flexplate http://store.summitracing.com/partde...I&autoview=sku I think the aps jus has them listed the same, cause its listed for auto tranny.
