Velocity Speed Shop
Relocating Rear Shocks
Does anyone know if I need to use a shock relocation kit on the rear end of a 69 if the rear end is only lowered 4"? I have been trying to do some research to find out and I'm still not sure. When I look at the LMC catalog they say that I only need rear drop shocks when It's lowered 4" with coil springs. The front will be lowered with just 2 1/2" drop spindles and the rear with 4" coils and just shocks, but do I need to relocate them do decrease the angle to 15 degrees or less. I think I have confused myself now........sorry.
Re: Relocating Rear Shocks
the closer the shocks are to vertical the more effective they work/i relocated my dropped shocks on a 4" drop and the truck rode alot better
you know you should also get the adjustable panhard bar on that 4"drop so you can center the rear axel
67-72 Addict!
cdowns is correct. Mine is lowered 4" with no relocators and it's ok but would probably be better with them. I think some have flipped the existing brackets and got the same effect as the kit.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
WTB this ad
The brackets will also have to be swapped from one side to the other when the're flipped. This is going to leave a gap between the shock bracket and the trailing arm. You can fill the gap with washers or build a shim.
