Old 11-03-2002, 01:38 PM   #1
pickupman
pickupman's Avatar
Info Needed-3spd overdrive
I need some info and possibly some parts on the 67-69 Factory 3spd overdrive trannys. I have a customer that wants to put it in his truck but not sure of exactly how it works. I have the transmission and I believe the cable. But there is some type of solenoid? on the rear of the tranny with some wires and a plug. What does this go to? Does anyone have what it goes to? Will the overdrive work without it? Any help will be appreciated.
Thanks, Bill
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is online now   Reply With Quote
Old 11-03-2002, 02:51 PM   #2
basketcase
basketcase's Avatar
overdrives
Hi Bill,
First you need to be sure which overdrive trans you have. Through the '50s and into the '60s they were an iron case with no syncro in 1st. In the mid '60s they switched to a Saginaw trans that used the same aluminum case as the all syncro 3 speed and Saginaw 4 speed found in Chevelles, Novas ect with low horse V8s. One slick trick, covered in Hot Rod Magazine many moons ago, was to remove the o.d. unit from the back of a Saginaw 3 speed and mount it on a Saginaw 4 speed. Now you have an 8 speed trans.
Sounds like you are missing many small parts that have long since been discontinued by GM. The solonoid that actually shifts the o.d. in and out is located on the side of the o.d . unit. It is controlled by a switch through a relay. The switch is mounted on the carb. When the o.d. was ingaged, by either having the cable pulled out or pushed in (I can't remember which) you would accellerate as normal. You would then let clear off the gas pedal and when the accelerator linkage returned to closed it would hit the switch. The switch would activate the solonoid either engaging the o.d. or disengaging it, depending if you wanted to shift up or down. You could do this in any gear. Also with the o.d. engaged your car/truck would freewheel like pushing in on the clutch when you let off of the gas; the engine didn't help slow the car down. With the o.d. disengaged the 3 speed functioned as a normal 3 speed.
When we used to put these things in our '55-'57 Chevy cars back in the early '60s (we couldn't afford 4 speeds) we would junk the cable and carb switch contol. Then wire the o.d. lever in the engaged position and hook the relay to a push/pull switch mounted on the shift lever. Then you could just split gears like in a big truck without all of the adjustment problems associated with the carb switch and cable. Hurst made a 3 speed floor shifter with the proper mounting brackets for the o.d. trans.
I sold a pile of this stuff about 12 years ago. I found a solonoid for an iron trans a while back in a box when I was moving into my new shop. It won't work on the Saginaw though. If your customer wants to proceed you will need to get a Hemmings and start calling vendors. Going to be a long search I fear. A better solution would be the Tremac 3 plus overdrive available in the late '80s up on 4.3 v6s and small v8s. It has a top shift floor lever and a conventional 4 speed shift pattern. 3rd gear is 1:1 and o.d. or 4th in the pattern is about .67:1.
Good luck in your quest,
Tom
P.S. solonoid part number for '66-'69 3886326
switch part number 1998130
relay part number 1115812
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 11-03-2002, 03:56 PM   #3
pickupman
pickupman's Avatar
Thanks Tom, That gives me some idea. Never have had any of these in working order. That will give me somewhere to start. Here is a picture of the trans I have. it came out of 67 truck. Bill
Old 11-03-2002, 11:56 PM   #4
pickupman
pickupman's Avatar
ttt
Old 11-04-2002, 12:10 AM   #5
basketcase
basketcase's Avatar
A thing of beauty. One of the rarest ones I ever saw was a customer at the Chevy dealer I worked at in the early '70s. A 1969 Nova 2 door with the 4 cylinder and the overdrive 3 speed. I've never seen another one like it. He always owned overdrives and thought that the Chevy II four would get great mileage so that is what he ordered. I guess this is one of those cases where rare isn't necessarily desireable. This car was much rarer than an Ss Nova with a 396/375 horse 4 speed but which one would you want?
Old 11-08-2002, 10:34 PM   #6
pickupman
pickupman's Avatar
ttt
Still Looking for some 3spd OD parts. ANYONE?
Old 11-08-2002, 11:33 PM   #7
basketcase
basketcase's Avatar
Here's a place that lists overdrive relays. Maybe they have more.
http://www.car-nection.com/yesteryear
This guy has overdrive in his ad too:
SPIRAL shocks, $100; batwing air cleaner, $1,400; 57 continental kit, 55 hdtp doors; 57 positrac, $1,350; NOS 57 power antenna, $900; power steering, $350; HydroVac power pac heads, $250 pr; motors, transmissions, 2-bbl & 4-bbl air cleaners, $75-up; intakes, single & 2x4 overdrive, relays, wheels; 55 accy bumper & grille guards; shavers, $300; 55/56 jacks, $150; many other parts. 913-268-5314, KS
And this one:
NOS 55-56 OVERDRIVE relay, $40; remote control mirror, $300; 57 Bel Air grille, $250; 56-57 ring and pinion, $300; 56 accumulator/dryer, $100; used: 56 padded dash center trim, $75; 57 Electrovac (top half), $200; 57 1271 carburetor, $125; 55-57 convertible rear regulators, $200. Alvin Shepheard, 817-498-7877, TX.
Another one:
CHEVROLET 3-spd OVERDRIVE transmissions, 1965-71 cars & trucks, rebuilt, $1,500 fob. 707-939-1993, CA.
Might be a lead.
Tom
P,S, Ads from www.hemmings.com
