Old 04-28-2008, 07:55 AM   #1
Nima
Blue 67
LT1 Vs LS1
Can someone through some light about these engines? what do you prefer if you had options and why?
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 04-28-2008, 08:08 AM   #2
TravisH
TravisH's Avatar
Re: LT1 Vs LS1
LS1 > LT1
All I've ever heard about LT1 is the optispark is crap and theres not many complaints on an LS1. Hit up ls1tech.com and you'll find out lots
TravisH is offline   Reply With Quote
Old 04-28-2008, 07:06 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: LT1 Vs LS1
The LT1 is a Gen II motor and the LS1 is a Gen III motor. LT1 is an iron block and LS1 is aluminum. Both are 5.7L/350ci. The Gen III's also include the iron 4.8, 5.3, and 6.0 truck motors and a few aluminum 5.3's.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-28-2008, 07:26 PM   #4
steelhorse
steelhorse's Avatar
Re: LT1 Vs LS1
The LT1 has just begun to get some aftermarket support.The LS1 is a much better motor with lots of aftermarket support.Just my .02
steelhorse is offline   Reply With Quote
Old 04-28-2008, 07:36 PM   #5
TonyJohnson
TonyJohnson's Avatar
Re: LT1 Vs LS1
The LS1 has better heads, intake, mains, cooling and ignition, IMO. (I was a die-hard LT1 guy since they were introduced...) The LT1 can be built to run just as well as the LS1 with effort and can be had for cheap. The LSx is a really kingpin engineering job and a GREAT bunch of engines. They have issues over 700hp keeping the heads bolted to the block. IMO, LT1s will be orphans in a few years... Go LSx for the future.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 04-28-2008, 08:03 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: LT1 Vs LS1
GM engineers took the best engine platform ever (the SBC) and revised and improved upon it. The LSX engines have crossbolted 6 bolt mains, a front mounted gear driven oil pump, and symmetrical high port 15 degree design is superior to the 23 degree siamesed Gen III and older heads.
With that being said, both the LSX, LT1, and even the old antique TPI's are great engines for our trucks. They're as good as (and usually better) than stock big blocks in terms of performance, and get much better fuel mileage on average. If I were building something to where being fast was most important and economy was not an issue, I'd go Big Block, Gen I, LSX, and LT1 in that order. I put Gen I in front of LSX simply because it costs much less to build max effort HP Gen I than the LSX.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-28-2008, 08:53 PM   #7
Billla
Billla's Avatar
Re: LT1 Vs LS1
The LT1/4 was a "bridge" engine between the late GEN Is and the LS series. As such, it's basically a GEN I with a few tweaks - the most notable is reverse cooling, which means only heads built specifically for the LT1/4 work. They're solid, workhorse engines with (as noted) improving aftermarket support and pretty much past the some of the early (94) reported problems. The power potential is a bit better than a GEN I, and the FI system is simple, elegant and honestly it's just a good looking engine
The LS is...well, it's magic. The power numbers seen from these engines is incredible, even in very streetable trim. The only downsides are that they require a fair bit of effort to make fit, although the aftermarket is making this easier by the day and that the aluminum ones are still fairly expensive as pull-out engines...but still cheaper (and more driveable with better economy and power) than a GEN I built to the same level.
The bottom line is that if I was starting a new project right now seeking 400+ HP and with $5K or so in the budget, it'd be an LS hands-down. I've got a 6.0L sitting on the floor that I just haven't got to yet
That being said, I'm building an LT1 383 for my Impala SS as the LS swap was just too complex/expensive, and I'm planning on transplanting the existing Impala SS iron LT1/460 trans into my 1972 C10 with a quick refresh. Considering a distributor/carb for that setup...
All IMHO, of course
Billla is offline   Reply With Quote
Old 04-28-2008, 09:56 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Re: LT1 Vs LS1
The LT1 is a great motor, but the electronics on it makes it a bit of a pain to deal with. The distributor is finicky if it gets wet and causes one to hate the process of dealing with it. The shaft driven water pump is great UNTIL you have to change out the drive shaft and the bearings (Been there-done that). I have a LT1 in my 95 Impala SS and it runs great, but the LS-1 will walk around it and is also 100 pounds lighter. I have a 2000 LS1 im my garage that I am working to put in my 68 Chevy C-10 and I like the Gen III design. There are so many parts built for them and it does not take much to drive the HP up on one of them.
piecesparts is offline   Reply With Quote
Old 04-29-2008, 02:09 AM   #9
ap2002
Re: LT1 Vs LS1
do it right the first time, go LS1, there are alot easier to mount and get it up and running, plus are a whole lot more reliable and put down very impressive numbers, thats what im going with on my 68 aswell,
from the info i have gathered, what you need is complete longblock motor with all accesories. painless wiring harness (~$600), motormounts, transmission, and a pcm computer, walbro255 fuel pump, make sure you also get the cable driven throttle body and you are set to go... the painless harness makes it a whole lot easier to install...
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 04-29-2008, 03:43 AM   #10
jkade
jkade's Avatar
Re: LT1 Vs LS1
LSX all the way, LT1's are to be left where you find them in my book.
jkade is offline   Reply With Quote
Old 04-29-2008, 03:58 AM   #11
BP68
BP68's Avatar
Re: LT1 Vs LS1
LT1 was a cool engine, but LSx is the way to go nowadays. IMO. Start searching and you may find a deal one way or the other. I have a 95 Vette LT1 is need of a cam and basic rebuild (rings/bearings) I am selling it, because I realized if I ever go fuel injected in my 68 it will most likely be a LS series motor.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 04-29-2008, 05:26 AM   #12
68GMCCustom
Re: LT1 Vs LS1
some of the various performance mags I read have done tests on LS series motors...the most notable was on an 345hp LQ9 6.0L truck motor. With the stock rotating assembly and upgraded cam and valvetrain, heads, headers, and tuning... they had it over 500hp....before putting a blower on it and taking it up to almost 700hp.
Kurt -
Old 04-29-2008, 05:51 AM   #13
oscareltemblo
oscareltemblo's Avatar
Re: LT1 Vs LS1
lsx by far check ot my build ? and you can keep it efi or carbed any way it will be awesome..
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
oscareltemblo is offline   Reply With Quote
Old 04-29-2008, 06:28 AM   #14
streetstar
streetstar's Avatar
Re: LT1 Vs LS1
Do an LS unless you can get the LT cheap.
I was (and still am) a die hard big block guy, but the new stuff is pretty cool
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-29-2008, 08:09 AM   #15
Nima
Blue 67
Re: LT1 Vs LS1
I guess the verdict is in, LS series. If you get a donor car, let's say a 2000 and up can you use all the wiring and pcm from it ot it has to be reprogrammed?
Old 04-29-2008, 03:31 PM   #16
ap2002
Re: LT1 Vs LS1
you could use the harnesss but there will be a whole lot of cutting a splicing to use, so alot of people go for a custom harness and saves people alot of headaches and will look alot cleaner, and it is always recommended to reprogram the computer.
Old 04-29-2008, 04:33 PM   #17
Orange
Licensed to Thrill!
Orange's Avatar
Re: LT1 Vs LS1
LS1 owns the LT1!
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 04-29-2008, 08:33 PM   #18
68GMCCustom
Re: LT1 Vs LS1
just set it up with one of these and a good ole carb!
ls1 carb
or....go with the new dual quad seup:
ls1 dual quad
Kurt -
