Old 04-28-2008, 08:32 AM   #1
pissonNOS
senior member
pissonNOS's Avatar
i have a bit of a problem after my c notch instal
before i installed these my front tires were rubing bad on the inner wheel well, now after i installed them im an inch higher in the front than the back and i have no more rubbing, would c notches change the geometry that much? also what are you guys doing about panhard bars and the c notch, im glad mine was only in like 2 threads because it hit the notch and pulled right out. some one have some answers or solutions for me?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 04-28-2008, 05:23 PM   #2
bedsled71
bedsled71's Avatar
Re: i have a bit of a problem after my c notch instal
was that before the c notch or becuase you lowered the rear of the truck
bedsled71 is offline   Reply With Quote
Old 04-28-2008, 08:00 PM   #3
larry may
Smile Re: i have a bit of a problem after my c notch instal
Not sure what this critter is but sure is a neat clean looking job.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 04-28-2008, 08:57 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
before i notched it my truck rubbed. but after i looked at it this morning i noticed my cups had come loose some how and got all cockeyed in the pocket which was preventing me from going all the way down i kinda feel stupid now
69 GMC bagged
Old 04-28-2008, 08:58 PM   #5
XXL
Seņor Member
XXL's Avatar
C-notches won't change the geometry at all unless you were already sitting the frame on the axle, in which case, you freed up the rearend to move upward a little.
As for the Panhard bar, for the long "track bar" type from ECE, it will hit the C-notch bracket. When I still have a stock frame back half with C-notch, I made the passenger notch longer to allow the Panhard bar to slip up into the notch. Search this forum for a variety of solutions to this problem.
XXL is offline   Reply With Quote
Old 04-28-2008, 09:01 PM   #6
pissonNOS
senior member
pissonNOS's Avatar
ok thanks
69 GMC bagged
