Old 04-28-2008, 05:16 PM   #1
P_A
P_A's Avatar
Big block headers
Here is a question for all you big block guys. Has anyone tried block hugger headers. Summit has a set of coated block huggers for just under 200 bucks. They look like they might fit on the drivers side and clear the stock clutch linkage. Here is a pic. See what you guys think.
Paul
1964 C10 SWB Fleetside-396/M21 4 speed
1957 Belair-283/M21 4 speed
1972 Camaro
P_A is offline   Reply With Quote
Old 04-28-2008, 06:11 PM   #2
Slowmotion
Re: Big block headers
I tried several types and none fit. If these are new then maybe they will work. But I had no luck.
Slowmotion is offline   Reply With Quote
Old 04-29-2008, 08:21 AM   #3
NF65Fleetside
NF65Fleetside's Avatar
Im running a 454 in my 65' and I used these from summit racing, http://store.summitracing.com/partde...5&autoview=sku
They work great and give tons of clearance too.
NF65Fleetside is offline   Reply With Quote
Old 04-29-2008, 03:28 PM   #4
P_A
P_A's Avatar
NF65Fleetside, I bought a set of those from Summit. They fit great if you have an automatic transmission. I'm running a Muncie M21 4 speed. The problem is the stock clutch linkage. The #5 and #7 header tubes are in the way. I new this when i ordered the headers. I'm either going to modify the clutch linkage or cut and modify the header tubes. If the block huggers will clear, i will use them. The passenger side block hugger looks like it might hit the motor mount. The driver side looks like it will work.
Paul
1972 Camaro
