04-28-2008, 05:31 PM | #1 |
had to tow the 72 home today
Took my daughter out for an icecream, on the way home cruzin down the highway, I was only doing 50 or so. I asked my daughter if the truck was sounding louder than normal and she said yes. It sound like one of the mufflers was falling off or loose. I kept my eyes on the gauges and everything was where they are suppose to be. We went another nine miles and it was stayin about the same going through town it started to make a horrible noise like someone was rattling a coffe can with loose bolts in it.
This truck has always blew blue smoke at startup and then it clears up. A week or so ago I was low on oil I added a qrt and everything seemed to be fine. I am hoping to bull the valve covers off today or early this week, I am not sure what I will find. This truck was currently just used to go for a quick drive it's not my daily driver so that is a good point. the truck has a 400 big block.
Mike K Friend of Bill W |
04-28-2008, 05:39 PM | #2 |
laying low
Re: had to tow the 72 home today
So did it quit running or did you shut it down for safety sake? Does it still do it at idle? If there are no spikes or dips in the oil pressure and engine temp it may not be anything real serious.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-28-2008, 05:45 PM | #3 |
head gaskets going out, or rings. did the muffler fall off or not?
04-28-2008, 06:14 PM | #4 |
A few more details oil pressure seemd to be steady, I shut the engine down once I was able to get the truck to the side of the road less than a 1/2 mile at low speed. there is almost n rattling noise at idle but once you tap the gas peddle it's loud.
04-28-2008, 06:26 PM | #5 |
Auto tranny? It could be the flex plate, or loose bolts between the flex plate and the torque converter.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-28-2008, 06:29 PM | #6 |
laying low
There are lots of things that could cause the noises. Several come to mind. Loose torque converter bolts, broken flexplate, loose flywheel dust cover, fan blades cracked or rubbing the fan shroud.
Is the engine still running smooth or has a miss developed? You may need another pair of ears to go under the truck while someone revs the engine to help narrow the search.
04-28-2008, 08:48 PM | #7 |
The blue smoke at start up is caused by your valve stems seals being worn out, which are located on your exhaust and intake valves. Like everyone has stated there could be many different problems with the engine. But if all your gauge were looking normal then check your valve adjustment. I had a similar problem and it was a clicking or tapping noise. I could hear at idle and at high speed rev's. GOOD LUCK!
...try'n to be a little! This is a great site. http://67-72chevytrucks.com/vboard/s...d.php?t=157669 http://www.67-72chevytrucks.com/vboa...d.php?t=375640 |
04-29-2008, 02:35 AM | #8 |
question would doing a compression check be worth anything ?
04-29-2008, 03:25 AM | #9 |
Commander Taco Bello
i don't see how that could hurt. at least then you could rule out a head gasket, rings, and valve seats.
04-29-2008, 04:19 AM | #10 |
Rockers backing off maybe or timing chain or???????? Noises suck!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
