More hobbies than money!
Hiddin Hitch
Got the hitch all set up and ready to go this weekend. Well the truth is I installed the hitch last summer. But just got all the wiring done the way I wanted it. Took off the old rusty 7 pin and installed this 7 pin 4 pin combo. Worked out just as I wanted it. Did a little polishing on the bumper while I was there and got a picture of the new exhaust while I was at it. Going to tow my boat about 2 and a half hours to a boat meet this weekend. Wife will drive it.
'70 cst10/swb 350, 3 on the tree, factory buckets. '70 GMC lwb 350/350 ps,pb '72 c-10 lwb 350/350 a/c, ps, pb '72 Blazer project |
Re: Hiddin Hitch
Couple more set up ready to go!
Skinned knuckles
Re: Hiddin Hitch
I don't see no hitch.. I guess that's the idea...
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) ![]() '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
Re: Hiddin Hitch
Got the hitch from early classics. The wiring stuff came from advanced auto.
Moderator
![]() Join Date: May 2007
Re: Hiddin Hitch
That is nice! Do you know if the hidden hitch will work if you have relocated a Blazer tank underneath your truck?
Re: Hiddin Hitch
Great job! I like how the plug still hides under the plate. I might have to steal your idea for my hidden hitch wiring.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
Re: Hiddin Hitch
That looks great. Leddzepp, ECE has a picture of the hitch installed on a 2wd Blazer.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: Hiddin Hitch
looks good i need one of those
Re: Hiddin Hitch
Looks like a blazer tank should fit. The 4 pin connector and the insert came with the hitch. I thought it was a pretty good deal as the kit. There was just enough room between the plate cradle and the hich for the wires. I was concerned about getting to the hitch pin, but works really well. I added the 7 pin because I have a 5 pin on my boat and I have a 7 to 5 adapter. Liked having the 4 pin there also for a small trailer I have. I'm getting excited, after 7 years owning the truck I'm finnally making some headway.
Moderator
Re: Hiddin Hitch
71SWB...Where is that pic? I cannot find it on their website....
Re: Hiddin Hitch
leddzepp, it's on their catalog. I will try to find it and scan it in for you. It's a pretty cool picture actually.
Moderator
Re: Hiddin Hitch
Thanks 71SWB, if you cannot find it, don't worry. I am going to keep looking for the pic too
#13 |
Re: Hiddin Hitch
I want one!
Joe |
#14 |
Re: Hiddin Hitch
Here is the ECE picture. Click on it for a bigger image.
wnc mountain, it looks like you have quite the boat too. We need a picture of the rig all hooked up and ready to go.
#15 |
Re: Hiddin Hitch
There is a different part for the Blazer and truck but I would think the tank will still fit. Call ECE and I'm sure they can tell you for sure.
I will get a pic of the rig all hooked up I ment to take one yesterday on the test run. The old memory banks don't work like they used to.
#16 |
Always wrenching!!
Re: Hiddin Hitch
I did the same thing with mine........
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
#17 |
Re: Hiddin Hitch
Yes the tank will fit. as a matter of fact that is what I just came in from working on. i need to drill 4 holes real quick and I will be done. i will take some pics in the morning.
WNC where did you get that combination plug at? I like it! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 04-29-2008 at 06:19 AM. |
#18 |
Re: Hiddin Hitch
ECE has different hitches for the blazer/burbs & trucks. The rear mount gas tank requires the 'arms' of the blazer/burb hitch to be slightly shorter vs. the truck to avoid interference w/the gas tank mounting straps.
I also learned that on the trucks, they use the same P/N regardless if it's a leaf or coil frame. And w/slight modification, it can be installed in a later model GM truck as well.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-29-2008 at 07:03 AM. |
#19 |
Re: Hiddin Hitch
I still have mine setting on the garage floor. I might install it one day.
1997 GMC Sierra Ext 1965 Mustang |
#20 |
Re: Hiddin Hitch
Where did you buy the hidden hitch? and how much total was it?
#21 |
Re: Hiddin Hitch
Here is the info straight from Early Classic:
Hidden Receiver Hitch Kits Want to tow with your Classic without that ugly hitch hanging below your bumper? Our new Class 4 Hidden Receiver Hitch is just the answer. Designed for use with the stock '67-’72 factory rear bumper, simply flip up the rear license plate and insert the coupler. It’s that easy. We now offer the hitch components in a package deal: Hidden Receiver Hitch, Extended Ball Mount, License Plate Flip Frame and Flat Four Trailer Wiring. Our new Blazer and Suburban hitches are also finished and in stock, and feature the same quality design and powder-coated finish as our Pickup version. Drilling is required for installation, and every hitch comes with all needed hardware. -------------------------------------------------------------------------------- Options: #906-6772BHPU - '67-'72 Pickup -- $209.00 #906-6772BHSUB - '67-'72 Suburban w/o Wiring Harness -- $209.00 #906-6772BHBLZ - '69-'72 Blazer -- $209.00 Quantity:
#22 |
Gettin By on Gettin By
Re: Hiddin Hitch
Have to subscribe to this so i don't loose it. Very cool idea. Looks great.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
#23 |
Re: Hiddin Hitch
I've had this set-up on my 68 since 2000. It works great w/o even knowing it's there.
#24 |
Re: Hiddin Hitch
I went with a normal receiver hitch that just sticks out below my license plate (only cost $35 vs. $200) but really like the idea for the plug. I might have to get a flip license plate bracket and go that route...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-30-2008 at 08:18 PM. |
#25 |
1970 Daily Driver
Re: Hiddin Hitch
I made one out of tube steel for my 70 and added a steel trailer plug from NAPA. MY truck has a blazer tank and there was plenty room for the hitch.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 04-30-2008 at 08:42 PM. |
