Saving 1 truck at a time!
Front discs dragging!
Just installed a new mastercylinder and old power booster. The booster did not have an acctuator rod so I pulled one out of an older assy. I just read in the rebuild manual that the length of this rod is critical and must be measured with a "go/no go" gauge. I did not do this so wondering if this is the problem.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
CCRider
Jack up the front of the truck, and rotate the wheels. If you can feel a drag, loosen the nuts on the mastercylinder and pull it away from the booster. If the drag goes away you found your problem. I have also seen new mastercyclinders right out of the box be defective and do this. Good Luck
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
huh?
![]() Join Date: May 2000
I'll bet Tom is correct in his assumption that the brakes will loosen up, when you pull the booster away from the firewall. I know for a fact that the rods vary in length, so you might just have to pull the booster away, measure the difference in relation to the firewall, and take some length out of the rod. I'm sure I"ve made this reply clear as mud, but I hope it helps in some way...lol
![]() TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Thanks guys...I'll bet I can put a shim between the booster and the mastercylinder and it would loosen up too...thanks again. I will try that now.
I put a 0.075 washer between the MC and the booster and it seems to have solved the problem. Thanks for the help!
