Old 04-29-2008, 01:51 AM   #1
76bonanza
76bonanza's Avatar
headman elite question
Narrowing down my long tube header search.
couple of questions about headman elite.
one: how does the "thermal coating" hold up as good as ceramic? Not a daily driver maybe a weekly driver.
Two: the ball socket collector does the ball pivot in the socket and still allow you to seal?
Third mine is a 68 sbc what is the correct part number is it 69890.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 04-29-2008, 04:13 AM   #2
BP68
BP68's Avatar
Re: headman elite question
I would go with Ceramic coated. I got some long tube headmans for my 68 with an 89 350 block and Vortec heads. The were on the motor, and it was on the frame. Stored inside for a while, then outside covered in plastic for a while. The color dulled and looked worn and I had never even run them. They looked awful next to all my chrome stuff, plus the long tubes did not fit my frame very well, had to do some grinding, and they rubbed one of the lower control arm grease fittings.
Check out my build thread to see the fit and finish of my new mid length ceramic coated Sanderson's. I love em.
If you must have long tubes and you want them to stay looking nice for years to come, I say go with Ceramic coated. My .02
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 04-29-2008, 04:35 AM   #3
76bonanza
76bonanza's Avatar
I am going to go with long tubes I the performace better and I like the look of them. My other option is hooker comps coated from jet-hot the are around 350.00 I think.
1968 c10
lowered 3" 4"
Old 04-29-2008, 05:57 AM   #4
og350
og350's Avatar
i have a question if anyone has ever used flowtech headers? i have a 71 4x4 3/4 that im swaping the leaking 350/4speed/205 to a 350/400/203 from a 76 chev and dont have the money for good headers so i got some flowtechs. they fit in ok but some of the bolt holes dont line up at all. just wonder if i can grind the holes out of if that will make them leak?
og350 is offline   Reply With Quote
Old 04-29-2008, 06:08 AM   #5
andrewt2
andrewt2's Avatar
I have flow techs on my 69 c10 lwb, and my 69 swb stepside... they work... thats about it... the first set went on fine the second set the holes both had a little bit of slag from being welded in them so i had to drill out two holes... i dont mind them for the money (89.00 bucks new at autzone) but the passenger side comes out almost directly inline with the at. trans X member..makes it a pain in the A** for routing exhaust...
andrewt2 is offline   Reply With Quote
Old 04-29-2008, 07:20 AM   #6
lindsey
I installed a set of the Elite headers in my '83 chevy truck and had no complaints.
lindsey is offline   Reply With Quote
