Old 04-29-2008, 03:24 AM   #1
Smokejohnson
Smokejohnson's Avatar
Rim and tire size?
Hey guys what size of rim and rubber are u using on your AD trucks?
Smokejohnson is offline   Reply With Quote
Old 04-29-2008, 07:28 AM   #2
Daniel U
Daniel U's Avatar
Re: Rim and tire size?
15's right now, but I'm not sure what the final ride hieght will be. When I get there, I will probably be going larger.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 04-29-2008, 08:42 PM   #3
mylow53
mylow53's Avatar
some billit specialitys 18" with the kdw tire.. 4" offest in the rear
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 04-30-2008, 02:20 AM   #4
Smokejohnson
How wide are u going?
Old 04-30-2008, 04:01 AM   #5
SURFER1316
PM me, I did some research a while ago and got sizes/info on 5-10 trucks and what they run i'd be happy to share
If I don't get back in a day or so, be patient, swamped at work.
SURFER1316 is offline   Reply With Quote
Old 05-03-2008, 05:33 PM   #6
tylordurben
tylordurben's Avatar
id be interested in knowing over all size. front and rear to get these trucks down low. i was told 27" is the max = 205/75R15
tylordurben is offline   Reply With Quote
Old 05-04-2008, 03:25 PM   #7
Coronas56
Coronas56's Avatar
tylord , this chart might help you with tire Diameter.........http://www.miata.net/garage/tirecalc.html
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 05-04-2008, 04:44 PM   #8
tylordurben
thanks corona! the MII front end and the rear end we got for the 50 GMC have 5 x 4-1/2" bolt pattern. we have not had any luck finding 15" steel wheels locally, only 14". is there any draw backs from running 14" wheels? ill still have 26" - 27" overall diameter.
Old 05-05-2008, 07:43 PM   #9
SURFER1316
main thing is depends on what brakes u run. 12" rotors most times won't fit in a 15" wheel, let alone a 14
