Old 11-03-2002, 04:20 PM   #1
Low69CST
Best Electric fans
I"m about to order an electric fan kit from summit, has anyone tried any? Any advice to offer??
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 11-03-2002, 07:29 PM   #2
72ChevyCheyenne
72ChevyCheyenne's Avatar
I am getting the Flex-A-Lite dual fan with thermostat and A/C Relay.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 11-04-2002, 01:15 PM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used two 14" Perma-Cool fans and made a shroud.Part # PRM-19114,$83.94 each from summit.They work well for me.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 11-05-2002, 02:13 AM   #4
nate68
the only problem i had with my flex a lite setup was the fuseholder, it was the biggest POS and it was giving me problems so i changed it and now i'm fine.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
