still buypickupparts
"there is a will" but, is there a way
its been 5 ok longer years since the truck has been to this point to be put back together, is there a way to check the electrical connections because I have done changes from 5 years ago to today. and I would "well getting antsie" to see head lights working tail lights working electric fan working so on and so on. I have not bought a battery yet and I was wondering if these checks I want to see if like a battery charger could take place of a battery or is there something else?. is using a battery charger a bad thing or it just wont work.
please feed back so I can calm down
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
![]() Join Date: Aug 2004
Re: "there is a will" but, is there a way
Hooking up the battery charger should do the job just fine. I personally would just borrow a battery out of one of your other trucks in your sig.
Living In The Past
Battery charger works ok with one exception that I had. I did Putter's wiper delay and could not make it work right until I pm'ed him and he advised not to use charger on that switch. I pulled out a battery and it started working correctly.
I am a Referee of life.
It would need to be a high amp unit for some circuits.In other words a trickle charger probably will not power some of the stuff mentioned.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
