small to big block question
I am converting from small block to big block and to a 400 tranny. Originally had a 307/powerglide. The big block I am going to use was in a 1 ton C30, I know I will need to find another driveshaft, or can this one be made to work. Also, will the rear end I have on here support the big block and tranny, it is a 5 lug coil spring, Thanks in advance
![]() Join Date: Apr 2005
Re: small to big block question
I'm pretty sure you're going to have to change the drive shaft because the powerglide is shorter than the TH400. As far as the rearend, it all depends on the gears, posi or non posi and how much you
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Hart_rod is right on. Dont forget you will also need new motor mounts/towers (some years can be converted from others). What year is your truck?
A stock TH400 will do fine with a stock BBC. What rear is in the truck? 12 bolt? 10 bolt?
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
If it's a 12 bolt they came behind, SBC and BBC so it'll hold. The drive shaft may not fit, but that is trial and error there. Put the BBC as far forward as it will go so the valve covers and the distributor clear the firewall, this will also requite a longer shaft, you can install it and measure, then hit the wrecking yards to see it you find something, or a new shaft will run about $150. Find a newer one piece long shaft and have it cut down, good luck I have put about 5 or 6 BBC in short beds and they are a riot!
