Old 04-29-2008, 08:55 PM   #1
ampsyco
vent window seals
i want to change my vent window seals. i see in all the catalogs some rivets and a tool to install them.
has anyone done this themselves ??? are they regular rivets ??? and can a regular punch be used to install them ???
i just dont want to get it apart and not have something i need to finish the job.
ampsyco is offline   Reply With Quote
Old 04-29-2008, 09:12 PM   #2
slug
slug's Avatar
Re: vent window seals
no, they are special rivets
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 04-29-2008, 10:19 PM   #3
61hawk
61hawk's Avatar
They use a special "punch" to seat them, but I bet you could do the same thing with a punch ground to a point to flare the rivet and a flat punch to flatten it. There are a couple rivets that are fun to do even with the right tool. The top ones where there's not a lot of room to get the tool in there.
61hawk is offline   Reply With Quote
Old 04-30-2008, 01:09 AM   #4
SeanPaintsFlames
SeanPaintsFlames's Avatar
I did it with a regular rivet tool. It was a little tricky to get it in the corners without scratching the fresh paint on the frames, but it seems to have worked fine.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 08-27-2010, 02:34 PM   #5
brawley
Easy Does It
brawley's Avatar
what kind of rivet tool works for these rivets?
brawley is offline   Reply With Quote
Old 08-27-2010, 03:44 PM   #6
dean jendro
Old and crusty
dean jendro's Avatar
Take a look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=351471
dean jendro is offline   Reply With Quote
Old 08-28-2010, 08:02 AM   #7
ljackson
ljackson's Avatar
The special rivits I got from truckandcarshop were too short. I used regular pop rivits
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
