82 c10 wiring
new battery went dead i charge it an the next day dead.what shound i do what killing the battery
lucky knuckles
i had the same problem with my 82 when i bought it. i replaced the battery and it was dead again. at first i just disconnected it all the time. that became a pain so i opted for a battery cut-off switch
advanced had one for $8-10. it works great. |
Re: 82 c10 wiring
Just find out whats killing the battery.. Its REALLY easy on these old trucks.. Its not like new vehicles that you have to comand all the modules to sleep then test for them waking back up.. It sucks... Anywho... first thing is first... Have the battery tested.... then if its good do this...
Connect a DVM in line with the battery cable. Find out how much of a parasitic draw you actually have. IN milli amps Note the battery reserve capacity. . Divide this number by 4. Example: 90/4 = 22.5 Compare this to the DVM reading. The current drain in milliamps should not exceed this number. Example: if a battery has a reserve capacity of 90 minutes, the current drain should not exceed 22 milliamps. Then once you know for sure you have a parasitic draw, while the DVM is still in place.. remove the fuses one by one until the exessive draw goes down to normal on the DVM.. Look at glow box lights, radio, underhood light, horn, etc..
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#4 | |
Living Legend
Re: 82 c10 wiring
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. ![]() project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony ![]() |
One shot, one kill.
Re: 82 c10 wiring
Spudz nailed it. Generally the older trucks should have less than 10 MA parasitic load. Another thing to check would be the alternator. If the rectifier bridge or the diode trio fail it can draw the battery down overnight. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
