Old 04-29-2008, 11:46 PM   #1
biggreen292
5 speed swap
took the truck to the swap meet yesterday which is a couple towns over by way of a secondary highway, i'm not really diggin the 3000ish rpm at 50mph. my buddy has a 92 1500 with a 4.3 and a 5 speed, hes pulling that for an lt1/4l60e and i'd love to put that tranny in mine. i know i need to get a tranny crossmember, mine has the cast iron bellhousing so the tranny just hangs out in space, not sure if i can use my mechanical clutch linkage or have to make it hydraulic, also not sure if the 5 speed is longer or if it has a different output shaft. hell i'm not even sure what it is its either a borg warner or the gm cast iron unit, most likely the borg being behind a 4.3.
anyone done this or something similar? theres no way an auto is going in there, so sick of driving automatics.
http://i16.photobucket.com/albums/b3...fleet041-1.jpg
71 custom camper/20:292/saginaw, my first pickup
83 cutlass cruiser:307/th250c, lifelong project
96 caprice 9C1:LT1/4L60E, police package
83 buick regal estate: buick 350/m20
69 bel air:250/m21
biggreen292 is offline   Reply With Quote
Old 04-30-2008, 12:24 AM   #2
CPNEJR
CPNEJR's Avatar
Re: 5 speed swap
it's probably the NV3500. they'll hold up to around 250 HP or a little more. the speedo is electric also. you will have to convert to a hydraulic setup because of the clutch fork being on the right side.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 04-30-2008, 12:32 AM   #3
biggreen292
Re: 5 speed swap
its on the passenger side???? thats f-n weird.
you got a g-body buick wagon! don't get rid of it..unless it comes into my yard
69 bel air:250/m21
Old 04-30-2008, 01:02 AM   #4
CPNEJR
CPNEJR's Avatar
Re: 5 speed swap
yea it's a rust free wagon. it's a 4.1 v6 and th200. it's a nice cruiser but it's down a cylinder and i don't have any idea on why it's down.
Old 04-30-2008, 01:17 AM   #5
CPNEJR
CPNEJR's Avatar
Re: 5 speed swap
btw welcome from northern NH. i'm about 11/2-2 hours away.
i'm not sure if the 5speed will bolt up to the 292 without some kind of adapter. if it comes out of a 4.3 or 5.7 and you have a 350 it'll bolt up with no problems.
i converted my 88 from auto to a 5 speed and the hydraulics aren't cheap.
Old 04-30-2008, 01:33 AM   #6
slomotion
Old Duffer
slomotion's Avatar
Re: 5 speed swap
How was Amherst? We used to come down from Maine, but it seemed to be drying up. Last time we were there it wasn't at all like it used to be.
I put a T5 behind a 292 and used the original clutch linkage and no extra crossmember. I needed to make a bushing to make the T5 bearing retainer fit the 292 bell housing. (The retainer OD was 5/8" smaller than the bell housing ID) With my third member ratio the T5 allows 65 MPH at 2100 RPM. I don't know how this compares to the trans you're thinking about, but this sure made my C20 a lot more fun to drive.
Welcome aboard!
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 04-30-2008, 02:33 AM   #7
biggreen292
Re: 5 speed swap
250 and 292's are the same bellhousing as a v8 so i know thats not a problem, if i need to go hydraulic i'll get the whole setup from that donor truck and fashion it to my pedal.
i do have a t5 i just picked up, its from a mustang but a buddy of mine has a mustang t5 in his malibu, its a little more work but not a disaster like you'd think, in a malibu anyway.
amherst was ok but with the blah weather and carlisle going on it wasnt to full capacity, its very weather dependent i've found.
69 bel air:250/m21
