Grandson's 71 with posi pops when taking off going around corners. Seems to be ok on straight pull. Truck has 250K on it. I purchased GM additive but not add it yet. What else can I expect? Are the clutchs for these still available if I have to tear her down? Thanks for your help.
------------------ Bill Rapid City, SD 67 short stepside, in weeds 6Cyl 69 Longhorn CST 396 nice original
Bill Rapid City, SD 67 short stepside, in weeds 6Cyl 69 Longhorn CST 396 nice original |
I'm not an expert but I do know that most posis make some sort of noise weather it be a poping or whinning clicking so forth. I cont know how to rebuild these fine units but I wish you good luck.
------------------ 1970 shortbed(project) 350/350 dropped 4/6 21/2" flowmasters. Dropping bigblock idea and building a stout smallblock...
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
I believe that the clutches are still available, they were made by Eaton. I'm not an expert by any means though.
Nathan ------------------ 1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road. 55 chevy 4 door 150 47 Willys CJ-2A
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran ![]() Nathan & Tiffany |
![]() Join Date: Sep 2001
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
Sounds like the lubricant is contaminated. Drain and refill with appropriate rear oil and the GM positrac friction modifier additive. Might be a good time for a pinion seal and axle seals as well as the new cover gasket. It is possible to get rebuild parts. I went through my Eaton posi about 12 years ago. Clutches were about $50 a set back then and springs about $10 for 4.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
Used to race Corvettes,16 years, have a Posi in my 72. The "POP" is the Posi plates releasing. Problem is either worn Posi plates, posi springs or both. To remove a posi is not to bad, to install can be dangerous. The posi pack, plates and springs, have to be compressed for installation. We use two C clamps, then tap the pack in. If not done right the pack will come apart. I installed a rear end cooler on my truck, adds to the life of the posi.
------------------ 72 Cheyenne Super, Fleetside, Shortbed, Original Owner, Special Ordered 350ci/340hp, Auto Trans, 3:70 Posi, Tow Package Northern Calif
72 Cheyenne Super, Fleetside, Shortbed, Original Owner, Special Ordered 350ci/340hp, Auto Trans, 3:70 Posi, Tow Package Northern Calif |
I had one years ago in a '72 that started popping like that. I changed the fluid, put in the GM additive, and the popping stopped. Never had another problem with it.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
