Didn't get much response over on the engine forum, so here goes. looking to build an engine stand. need it to be able to hold a big block or a heavy diesel motor. anyon got any plans or advise?? thanks
Re: engine stand
unless you can get the materials for free,or you really want the challenge of building it yourself....they are pretty reasonable to buy.
![]() Join Date: Aug 2007
Re: engine stand
![]() Join Date: Jan 2006
Re: engine stand
i paid 50 bucks at HF for the 1000 lb stand. the 2000lb folding cost about $110. i can understand if you want to build it yourself, but personallly I would rather put that tiime into my build.
Re: engine stand
Or are you talking about an engine Testing Stand?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Re: engine stand
not a test stand, just an ole engine stand to build motors on
Re: engine stand
I buy this one from harbor freight. They are the best stand for the money I have found. Have 2 right now.
![]() I started building my engine test stand last night.
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! Last edited by puppy; 04-30-2008 at 04:44 PM. |
I am a Referee of life.
Re: engine stand
Unless you have the heavy wall square tubing and casters already you can probably buy it cheaper than you can build it.I priced steel for a 4X8 workbench a few weeks ago and for 6 legs 30 in.2x2 angle for a frame and 1/8 sheet 4X8 was about $1000.00 and that's no typo.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Gone to greener pastures
![]() Join Date: May 2007
Re: engine stand
I've seen them at Costco too.
But, beings that they "turn the store over" ever 30 days, they may not always be available. I built mine from scrap. But at that time I worked in a refinery and was able to scrounge free steel from the "boneyard." And, I was taking a welding/metal shop class at night at the local H.S., so I had a complete metal shop with all the fancy equipment at my disposal. I learned how to run a vertical mill on that particular project.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Re: engine stand
I agree.... buy the HF one, while your there buy some better casters so it will roll around easier.
My buddy says mine looks like a monster truck.... I went a little overboard but it rolls super easy, I even rolled it through the grass in the front yard (with the motor on it).......because I could.. ![]()
R.I.P. Scott Kalitta
