Aluminum slot wheels rule...
Lug nuts for slots
I got a set of 16.5 aluminum slot wheels for my GMC and I need some lugnuts so I can put them on. What kind/type of lugnuts do I need? Thanks for the help guys/
Re: Lug nuts for slots
![]() The PO of one of my trucks just used acorn lugs --- i've been too busy with my job to even take them off to check stuff out in th 2 weeks i've had it though-- so i don't know anything else about it
Are you retired too? Nonsense! I'm in my prime |
Texas Big Wig
You need a set of 24 & the studs are 7/16" the lug nuts for mags are commonly referred to as acorn nuts
need the sleeved lug nuts for the mags
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
A tire place can get them.I get them at Pep Boys.I don`t know if you have them in Maine.
So do I need acorn nuts or the mag wheel/sleeved type ones? I'm getting mixed info.
Trucks N Tranzams
Here is where I bought mine. Great guy, fast shipping!!!!
Tell him what you need, he's got them. http://stores.ebay.com/TorqueThrust-...QQftidZ2QQtZkm
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
ttt....I want to get these wheels on soon.
member #16
![]() Join Date: Dec 1999
Can you post a pic? different brands may vary. The acorn nut type will have a taper like a regular lug nut. The sleeve type has a larger hole with no taper and usually a machined spot for the flat washer.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 05-01-2008 at 12:11 AM. |
These are the sleeve type that need washers. But they have alot of sleeved lug nuts available, and I need to get the right size shank. I mesured it and it came to 23/32"...so maybe its 3/4" and I just measured too close?
Does anyone have a part number for what lugnuts to use to put the slots on my 68 GMC 3/4ton 4x4? An exact, correct p/n would work really good.
![]() Last edited by JAKES 68GMC; 05-01-2008 at 10:57 PM. |
