Old 04-30-2008, 06:33 AM   #1
gonline71
gonline71's Avatar
1971 Non Tilt Steering Column rebuild help
I need to know the order for the items in the picture. I am fairly certain it goes as follows...from left to right.
#1 followed by #2...then the column shifter housing....then #3 with the rubber side up....
Man I hope this makes sense.....
gonline71 is offline   Reply With Quote
Old 04-30-2008, 03:08 PM   #2
JimKshortstep4x4
Re: 1971 Non Tilt Steering Column rebuild help
The order that you show is not quite right. The schematic does not show the washer, (your #2) so I took a column apart to check on where the washer goes. The washer goes first, then the white plastic bearing, next the shifter bowl and then the plastic bearing with the rubber fitting into the turn signal support.
If we used your order as pictured it would be 2, 1, 3.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-30-2008, 06:38 PM   #3
gonline71
gonline71's Avatar
Thanks a million!
Old 04-30-2008, 08:20 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
The metal washer drops into the column first (it has a spot to rest on), then the plastic piece on the left. Then your shifter housing, the last plastic piece on the right goes on top. Your shifter rides between the plastic pieces. (No metal to metal contact).
Does that make sense?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-30-2008, 09:06 PM   #5
gonline71
gonline71's Avatar
Perfect sense. Thx
