04-30-2008, 04:38 PM | #1 |
Which Doors seals are best
I know there is a bunch of experience on this board. Which door seals work out the best the original clip type, soft seals. glue it. What did you guys use and what are the pros and cons for the different types. Any help appreciated.
Thanks |
04-30-2008, 11:05 PM | #2 |
Re: Which Doors seals are best
Save your lunch money and go with Steele Rubber, you wont be disappointed in the finished product, buy the whole kit.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-30-2008, 11:27 PM | #3 |
steele rubber is great, they are great to work with and make a great product.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
04-30-2008, 11:57 PM | #4 |
05-01-2008, 10:05 AM | #5 |
I still need door seals. Thnx for the info!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
05-07-2008, 03:14 AM | #6 |
I completely forgot about steele rubber and ordered te LMC kit...Ill be sure to do it next time on my 69 camaro.
05-07-2008, 03:52 AM | #7 |
I've tried both (LMC & Steele Rubber) put the door seal kit side by side & its a no brainer. I'm not knocking LMC, I've bought alot from them & have no issues with them, but if you want the best rubber, buy from the company that sells only rubber.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
05-08-2008, 02:05 AM | #8 |
Hey Kid thanks for the feedback sounds like steele rubber is the way to go.
05-08-2008, 10:41 PM | #9 |
Does this just apply to the door seals, or do the recomendations also apply to window channels, vent widow seals, whiskers, windshield seals etc.? I also need all of this for my 51.
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 Last edited by bretcopsey; 05-08-2008 at 10:43 PM. |
05-08-2008, 11:22 PM | #10 |
PITbut
05-10-2008, 04:26 AM | #11 |
bretcopsey, my comment only applies to the door rubber kit, consisting of the seal that glues on door, bulb seal that slides into the channel around door opening (on cab), & the blade rubber seals that run fwd / aft along the bottom of cab floor along door. I am not sure if Steele Rubber sells the remaining parts you mention.
