Old 04-30-2008, 08:07 PM   #1
Ilike 72"s
drop spindle with drums
Originally Posted by Ilike 72"s
I'm looking to drop my c10 3-5. I'm on a budget so I want to use a drop spindle with stock drums. Do you know if anybody makes one?? Dennis
Ilike 72"s is offline   Reply With Quote
Old 04-30-2008, 08:12 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: drop spindle with drums
unfortunately that is a no.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-30-2008, 08:41 PM   #3
70c10
67-72 Addict!
70c10's Avatar
On a budget (free) you can cut your front springs and get that drop you want. I did that before I did my disc conversion.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-30-2008, 08:45 PM   #4
Ilike 72"s
Where do you cut? The top and bottem of the spring has a small radius and gets large fast. If I cut even one coil, how do I reatach the spring?
Old 04-30-2008, 09:02 PM   #5
70c10
67-72 Addict!
70c10's Avatar
You cut the bottom. I have cut 1.25 coils for a 3" drop but you may want to cut 1 coil to see if you like the stance first. Use a cutoff wheel.
Jim
Old 05-01-2008, 03:25 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
If I'm thinking correctly, you can either cut your springs, or modify your lower control arms (creating a dropped LCA). If you use the search feature, you will find more information on this concept.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
