Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-30-2008, 09:24 PM   #1
Super73
Super73's Avatar
Going under the knife. Will take pics while I work.
Well,
Since I started loosing a head gasket and wanted to do some suspension re-engineering, my truck is parked right now. I am going to be doing some changes again.
1) Making a new upper front shock mount to accomodate the Rancho 9000's I bought. This will be fairly straight forward and made out of 3/16 plate.
2) Making my own anti-roll bar. I found some 1 3/4" sway bar bushings online for a RV. They are made of poly material and I got 4 with the kit. Bar itself will be made from 1 3/4" .188 wall. The leverage arms will be made from 3/16 plate and the plates going on the rear.
3) Going to make a new panhard bar. Reason for doing this is to A) make it longer and B) remount it to be closer to axle centerline. By making it longer, there will be less rear side shift under a bump on the street (Since I do cruise it around).
4) Pulling the wood out of the bed so I can C-notch the rear frame. I think I am going to mount the anti-roll bar and the new panhard in the C-notch. I think it would be a clean look as well as maybe keep them out of the way.
5) I'm also going to redo the exhaust from the X back. Going to dual cut outs then knecking it to 2 1/2" after the cut outs and in to a single "two-in" 2 1/2" to a single 3" out. I'm hoping this quiets it down when corked. Some times I can't hear myself think in it right now.
6) Gonna swap in the poly bushings I have for the rear control arms.
7) Make a new front Crossmember that factory control arms will bolt to (might buy tubular replacement sooner than later).
8) Make a square frame tonue cover.
7/8 I might not get to this round.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-30-2008, 09:29 PM   #2
Super73
Super73's Avatar
Re: Going under the knife. Will take pics while I work.
BTW, This happened while cleaning my valve covers. Six stitches and I can't play sax for a month I was pulling the filler piece out of the valve cover and it didn't want to come. Finally poped and the valve cover met face. I do not advise any one to do this. At first I thought I might have knocked out my front teeth.
Old 04-30-2008, 11:00 PM   #3
regan wilson
regan wilson's Avatar
I guess you will remember that for awhile ! Maybe you could file for dissability ? lol ....Keep us posted .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 05-01-2008, 12:54 AM   #4
prostreet1967
prostreet1967's Avatar
cant wait to see some pics. mines under the knife now as well. doing step notch and removing panhard bar for diag track bar. remounting shock bar. will post some pics later.
prostreet1967 is offline   Reply With Quote
Old 05-01-2008, 05:09 AM   #5
djracer
djracer's Avatar
that sounds like allot of work. Have you ever tried spraying it out of the hole?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-01-2008, 07:06 AM   #6
Super73
Super73's Avatar
Kevin,
Only once. Lifted both front tires. Once they came down it unloaded the rear. Front shock needs to be stiffened up. There are a lot of little things I am noticing that I am trying to resolve.
Old 05-13-2008, 11:45 PM   #7
Custom 68
Custom 68's Avatar
how come you are changing the front shock mount? I too am thinking about the Rancho 9000 also. Which ones did you get and where...
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-16-2008, 04:03 PM   #8
Custom 68
Custom 68's Avatar
any word on this? I have read some about the shocks and for the price am curious on how they will work. I understand the get stiff the quicker they are moved. This is opposite of what I think I would want for the street. I would think you would want it to absorb the bumps (fast movement) and under cornering (slow movement) you would want a firmer shock.
Maybe for drag racing this shock is ideal?
any thoughts...
Dave
Old 05-16-2008, 04:47 PM   #9
71Dragtruck
71Dragtruck's Avatar
any thoughts...
For drag racing you want a front shock that extends really fast for weight fransfer to the back, and then when it comes down they settle realy slow so the front doesn't slam down hard and also to keep the weight back so your rear doesn't come unplanted. Shocks that have this type of valving are drag race specific and aren't any good in any other aplication and will handle poorly on the street.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 05-16-2008, 09:03 PM   #10
Super73
Super73's Avatar
Unless... You have sooo much stored energy that you need to slow the upward travel down more than a drag shock will allow for (this is my issue). Here a stiff/stiff shock would be good.
As far as the shock mounts, they are made and the shocks are installed. I went with Rancho 9000xl's and can give you the actual P/N tomorrow.
As far as how they ride? no idea, trucks motor is in piecces right now.
Old 05-17-2008, 08:13 AM   #11
Super73
Super73's Avatar
I'm sure this will help the confusion.. Sorry for the bad pic, cell phone.
Old 05-17-2008, 05:51 PM   #12
whatnow123
whatnow123's Avatar
Can you tell me kind of front springs are you running? I have the ECE 1.5 drop springs and get NO weight transfer at all to the rear. The front doesn't lift at all. My truck is worthless up to about 40, but it is quite a show.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 05-17-2008, 10:55 PM   #13
Super73
Super73's Avatar
Here is the thread on it..
But, please get a front end weight before using these. If your truck is heavier than mine, you will want a little different spring.
http://67-72chevytrucks.com/vboard/s...d.php?t=277773
Old 05-17-2008, 11:48 PM   #14
hotrod 80
mini truck racer
hotrod 80's Avatar
Any word on the RV swaybar / anti-roll bar ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-18-2008, 12:09 AM   #15
Super73
Super73's Avatar
No.. I did the shocks then pulled the motor.. I need to c-nothch the frame before I can finish the anti-roll bar. The only thing I am using from the RV is the 1 3/4" bushings.
Old 05-21-2008, 08:51 AM   #16
Super73
Super73's Avatar
Well boys and girls.. Here are some pics of the motor. I still need to finish polishing a couple areas, but take a look at the driver head in the first pic. That is the waterpump reflecting off the front
Old 05-21-2008, 03:14 PM   #17
djracer
djracer's Avatar
Sweet!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-22-2008, 01:05 AM   #18
shortbed70
shortbed70's Avatar
Dude you HAVE to post some more drag videos when you get done. Awsome motor. Wanna trade???????LOL
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-22-2008, 08:32 AM   #19
Super73
Super73's Avatar
Thanks for the compliment but Kevin, Bigjim and some others got some awesome rides. Mines just a lowly old farm truck
