65 Fuel Gauge - No workie!
Does any one know if the stock fuel gauge can be fixed? Or is it cheaper to put in an after-market one? Mine seems to be stuck on "F" (won't that be nice). I checked out the sending unit and it's working, I also checked it to the gauge and it has voltage and resistance.
Also, what is the stock color of the dash, can I match it? Thanks Guys |
It's Better With Nitro
Re: 65 Fuel Gauge - No workie!
You may have something simple as a loose wire, or connector right behind the gauge. If you pull the instrument cluster, check to make sure the needle isn't hanging up on something. If it's not, check all of the connectors at the gauge. It just could be something got loose, or some corrosion is not permitting current.
Council of the Elders
Here is some advice I would follow. Look at the second one first:
First, does the gauge go to empty when you turn off the key? If no, the gauge is bad. If yes, ground the sender terminal of the dash gauge. If it goes to empty, the gauge is good. If it doesn't the gauge is bad. If the gauge is good, run a separate ground wire to the tank (clean a spot down to bright metal). If the gauge goes down, you found the problem. If no change, ground the tank end of the sender lead. If the gauge goes down now, the sender is suspect and you will have to pull it out of the tank for a test. If no change, you have a break in the wire between the dash gauge and the tank. Source= Ray from another board Open circuit - gauge will read full. Grounded circuit - the gauge will read empty. THe most common reason for a gauge to read full is the sensor wire gets unplugged at the fuse panel. At the very bottom of the fuse panel, you will see a place marked fuel. There is a brown wire somewhere nearby (possibly under the floor mat) that plugs into the space on the fuse panel. That will normally fix it. If it isn't that - then the wire is broken somewhere between the fuse panel and the tank or the ground came off the tank. Replace the wire or ground the sensor. Source= Vaughn on another board
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
Great list of ideas, billydonn. You saved me typing all that stuff out myself!
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
![]() Join Date: Apr 2008
Great work on the troubleshooting ideas, guys. Hope it's easy to fix.
Regarding the paint - Color is Fawn, it's available at an automotive paint supplier, or can be ordered online. If you pull the dash cluster, I bet your tach could be mounted in the panel on the right side. Dan
1966 Chevy Suburban 'Gater - Shop Truck - 350/turbo 350 Power Steering, B&M Floor Shift, Dual side dump exhaust Chrome Rally 6 lugs. (((XM)))tunes! 1965 Riviera 425 - Luxury Muscle - Fully Factory Loaded. All power, A/C, Custom Interior, Guidematic Dimmer, AM/FM - etc, etc 1966 Corvair Corsa Turbo - Factory Sport Model - Quick steering, F-41 HD suspension, Positraction, Tele Wheel. |
![]() 1966-Suburban-V-8: Thanks for the paint info and the Tack idea. ![]() You guys Rock! I love this site.... ![]() |
Resistance is Futile
My 'burb has the same issue.........thanx for the info billydonn.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Wait a sec... the senders in these trucks were 0-30 ohms, so 25 ohms may read nearly full. The 0-90 ohm ones came later, but I'm not sure which year they changed.
not to thread jack but I got a 30ohm Autometer guage and when the tanks full it only goes to about right under half way....anybody know how to fix that?
The fuel gauge has a resistor that runs across the back. Over time the white resistance stuff disintigrates. I got lucky and found one that is still decent. I restored all my original gauges and got them working again. I added a couple other gauges to the dummy gauge holes. Its not perfect, but its a truck. I like the clean look, without gauges hanging everywhere.
#11 | |
Anyway I was wondering if anyone has ever heard of a sender working properly out of the tank but as soon as it is in fuel/tank it reads full. I have tried some checks from another board but cant get it to work once it is in the tank. The ground is hooked up in the same place with a wire to one of the mounting screws to the frame just like when I tried it outside the tank (and it worked). Is it possible the sender/rheostat might be faulty?? All the wiring is new and the sender is as well. I just cant figure it out why it works properly out of the tank but not in it? I did find out that the sender is a 240-33 ohm would this make a difference whether it works properly in or out of the tank?? This has me baffled. ![]() ![]() |
Hey i just did the same thing Tom did today, very nice. Did u have to cut out part of the back plate for the right hand side? Nice job....i used a tach that only sweeps like 100 degrees to avoid cutting...ill have to get some pics...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
#13 |
You can't beat the look of a factory tach in the 4-5-6 Chevy trucks. I have had several of them and they look cool.
#14 |
As far as i know the 4-5-6 dashes are the same. difference is between the the gauges and idiot lights
#15 |
1961 crewcab
so if you ae running a modern 0-90 ohm sender with an old 0-30 ohm guage, would the tank just read full until it was almost empty...?
I have a rear mounted tank out of an 1985, and a guage from a 60-63 that just reads full right now, the tank is about 3/4 full, but the guage stays at full all the time, and the needle just moves about a millimeter when you turn the ignition on and off. |
#16 | |
#17 | |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
