Old 05-01-2008, 01:23 AM   #1
Dusty_case
Dusty_case's Avatar
How can you find info on heads?
Hello I just found a 68 lwb and was woundering what motor I have. I ran the block and it came up as a 250/292. but I don't know whick it is or even it it is the same block for the 250 but with different bore and head with the 292
like I said I am new and i am still learning these things If I am wrong let me know please
1968 c10 250/3spd
Dusty_case is offline   Reply With Quote
Old 05-01-2008, 01:34 AM   #2
john
member #16
john's Avatar
Re: How can you find info on heads?
If your motor mounts are straight across from each other it will be a 250. If they are offset it will be a 292. There are other differences in side cover height and fuel pump location also.
john is offline   Reply With Quote
Old 05-05-2008, 06:09 AM   #3
Dusty_case
Dusty_case's Avatar
Hey John If you are checking back thank you. I have not had time to check it though.
1968 c10 250/3spd
Old 05-06-2008, 04:18 AM   #4
Dusty_case
Dusty_case's Avatar
I found that the 250 in a different block
1968 c10 250/3spd
