05-01-2008, 08:28 AM | #1 |
Life, Be In It.....
Is there a site that will help me determine the needed plug gap?
My 327 Engine
327 Large Journal Block .40 over Edelbrock Proformer RPM cam and intake Edelbrock 600 cfm carb World Torquer Heads Manley Swirl polishied 2.02/1.60 valves 67cc combustion chamber 3/8 studs Comp Cam roller tip rockers and lifters MSD Distributor MSD 6AL electronic ign
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
05-01-2008, 08:41 AM | #2 |
Gone to greener pastures
Re: Is there a site that will help me determine the needed plug gap?
Nice truck
Don't have any particular site info, but all the manuals sitting here next to me say it should be .045". Hope that helps.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 05-01-2008 at 08:41 AM. Reason: spelling |
05-01-2008, 09:37 AM | #3 |
Anything with HEI is gonna have .035 - .040, pretty much the standard...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
05-01-2008, 12:58 PM | #4 |
Since you have an MSD box in the mix, gap requirements are probably different from stock. Your best bet is to go to www.msdiginition.com and search the forums there.
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone 454/TH400/3.73 |
05-01-2008, 06:55 PM | #5 |
Life, Be In It.....
thanks for the input.
05-01-2008, 08:28 PM | #6 |
I think it's .060 when you are running a 6AL box.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
05-01-2008, 11:47 PM | #7 |
.035" for points ignition
.045" for GM HEI electronic ignition Whatever the manufacturer recommends for any other ignition. Check your MSD literature.
Tim |
05-02-2008, 01:00 AM | #8 |
its all about the +6 inches
If it is a driver, I would go a little conservitive on the gap too. Making more gap will wear out components quicker. So if MSD says .045 to .050.. I would go for the .045 personally.
05-02-2008, 02:10 AM | #9 |
jugernot- I'd like to know this information if you do find it.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
05-02-2008, 04:37 PM | #10 |
Life, Be In It.....
I called MSD yesterday and well I will say they were not very helpful. When I asked what gap should I use. The response I got was "Well what is the recomended gap for your engine. I said I think it is between .035 and .045. Response "well why not set it for about .040." It sounded like he was guessing and did not have a researched answer.
I was a little disapointed, because the amount of money you spend buying a so called quality part, they should have a better tech department for consumer questions.
05-02-2008, 04:43 PM | #11 |
Junk Junkie
With my Bigblock motor I used Delco R45TS plugs running a 6AL box, and gapped them .040 with no problems.
Mike 71 Chevrolet C-10 Short Bed Stepside 81 GMC 1500 Sierra Classic Long Bed |
05-02-2008, 05:56 PM | #12 |
I have no idea where .060 came from but that is way to wide...
05-02-2008, 07:08 PM | #13 | |
They revised it to .045" with R44T plugs. So that is where I'd guess the .060" came from
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
05-02-2008, 07:16 PM | #14 |
Junk Junkie
Aren't those for a colder heat range too?
05-02-2008, 07:31 PM | #15 | |
It's on page three here- http://www.msdignition.com/pdf/6%20series/6series.pdf
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 05-03-2008 at 04:58 AM. |
