Old 05-01-2008, 10:57 AM   #1
TimC63
TimC63's Avatar
Late Model Rims on Early Model Trucks
Hey Guys,
Came across some 17" (6x5.5) stock alloy rims off a 2007 GMC Truck which I'm considering using on my 1963 C10 because I think they're decent looking, better sizing, and pretty much a steal ($$$).
I'm currently running 15's which are nicely thrashed and I need to re-do the majority of the stock 7/16-20 lugs (4-wheel drum for now).
The only real issue I see in using the 17's is the newer '99-'08 14mm 1.5 lugs which the rims are designed for. The rims obviously have bigger holes for the lager 14mm lugs and require longer lug as well.
Anyone heard of drilling out the drums/axles/hubs in order to install 14mm 1.5 lugs so that late model rims can be used?
TimC63
TimC63 is offline   Reply With Quote
Old 05-01-2008, 02:41 PM   #2
billydonn
Council of the Elders
billydonn's Avatar
Re: Late Model Rims on Early Model Trucks
Originally Posted by TimC63 View Post
Hey Guys,
Came across some 17" (6x5.5) stock alloy rims off a 2007 GMC Truck which I'm considering using ... Anyone heard of drilling out the drums/axles/hubs in order to install 14mm 1.5 lugs so that late model rims can be used?
Attachment 357270
Never heard of it, though anything is possible. But the cost and hassle of doing that could be significant. IMO you will still have fitment issues with wheel backspacing though. Advice: be safe and go ahead and convert to disc brakes... you have one of the easy ones (63-66).
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 05-01-2008, 03:13 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
Go to one of your local tire/wheel shops and ask if they a have a conversion lug nut. I know that some where avaiable for fitting later model (88-98) 5 lug wheels (88-98 used 14 mm studs also) on to 73-87 five lug trucks that used 1/2-20 studs.
These "conversion" lugnuts had the correct external dimensions and cone shape needed for the later wheels, but had the internal thread of the older standard style. just a thought...
billy is right about the back spacing, you should check that out first to see if they are going to work for you...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-01-2008, 05:13 PM   #4
poorboy
poorboy's Avatar
These should work. Part #C2002
http://www.tradeunion.com/ToplinePro...gsspecial.html
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 05-01-2008, 06:13 PM   #5
BlueJeep
BlueJeep's Avatar
I've done it before, though not on one of these trucks. Go to a parts store, and have them pull a wheel stud for your application and have them pull the Dorman book on studs, and take a calipers to measure the knurling. If you're lucky, you might come close on one and not have to drill. On a positive note, 14mm is very close to 9/16 so that would be an upgrade.
If you need to do wheel spacers it's possible that you can order them to bolt on to your SAE lugs and have them come with 14mm studs, making it a bolt-on deal.
BlueJeep is offline   Reply With Quote
Old 05-01-2008, 06:18 PM   #6
jkaylor68gmc
jkaylor68gmc's Avatar
I have a set of 16-inchers off my 02 SIlverado with tires I would cut someone a serious deal on, I no longer need them.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 05-01-2008, 06:36 PM   #7
jchav62
1962 C-10
jchav62's Avatar
I think these newer wheels have a negative offset and they don't sit well on our trucks.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-01-2008, 07:46 PM   #8
joe231
joe231's Avatar
I would have to agree, I don't even like them on what they came stock, just because they sit in to the truck too far, just my $0.02
to each their own
CHEVY ONLY
Old 05-01-2008, 08:07 PM   #9
protrash64
Resistance is Futile
protrash64's Avatar
The other factor to consider is the centerbore of the new wheels........it may be somewhat smaller than your hubs and it will be more of an issue than the studs. IMO
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-01-2008, 09:50 PM   #10
TimC63
TimC63's Avatar
Thanks for the input everyone. Much appreciated.
Summary
- studs/lug nuts: conversion lug nuts sound like the way to go, longer studs still needed
- backspacing (5"): clearance is tight but shouldn't be an issue, possible wheel spacers
- center bore: ~3.5" rear hub vs. ~3" wheel, not gonna work, possible wheel spacers
Conclusion
- Don't you hate it when you get some wacky idea in your head you just can't shake? I think I could make the rims work correctly with the proper tweaks from above which are all minimal effort. I guess it really boils down to how cheap my friend will sell me the rims, maybe free , and I guess I'll find out how bad the backspacing looks once I mount them.
Thanks again for help guys! I'll post picks if I ever make this happen.
TimC63
Old 05-01-2008, 10:22 PM   #11
66shortwide
I know the fronts will not fit over the centers on the drum brakes - I guess u may could have them machined??
66shortwide is offline   Reply With Quote
Old 05-01-2008, 11:21 PM   #12
protrash64
protrash64's Avatar
Your 5" backspace will not be a problem.......I run deeper on both my trucks w/ no problems. Do the newer wheels use the conical seats? My pick-up has wheels for an 88-98 3/4 ton and I didnt change any studs. I just used 60* seats w/ the shaft that extends into the mounting hole.
Old 05-02-2008, 12:01 AM   #13
TimC63
TimC63's Avatar
protrash64,
Yes they use a conical seat type mounting hole. The below lug nuts are the factory deals that have outside male threads for the black plastic lug nut covers (never new those weren't the actual lug nuts until recently). I could care less about using the covers and if i can get away with using stock length studs, that might be better.
TimC63
Old 05-02-2008, 02:04 AM   #14
protrash64
protrash64's Avatar
I re-read what I wrote.........sorry TimC63, wasnt exactly clear. I used lugs that have the 60* seat and the shaft that extends into the mounting hole. They look similar to the dually lugs on the link in this thread......those are not the correct lugs, however.
Old 05-31-2015, 11:55 AM   #15
thumpros@yahoo.com
thumpros@yahoo.com's Avatar
TimC63,
What did you eventually do to mount your alloys, or did you?
Thanks!
Rod
68 C10 LS SWB LM7 5.3 700R4 http://67-72chevytrucks.com/vboard/s...d.php?t=692803
thumpros@yahoo.com is offline   Reply With Quote
Old 05-31-2015, 02:08 PM   #16
MusicMan70
MusicMan70's Avatar
Wheel spacer with correct lug nuts for the center cap.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-31-2015, 04:33 PM   #17
thumpros@yahoo.com
Thanks MusicMan70,
Nice clear picture. Just to recap. That is the 1.5", or 2" Spacer?
Thanks again...
Rod
Old 05-31-2015, 06:12 PM   #18
MusicMan70
MusicMan70's Avatar
Yes it's 1.5"
MusicMan70
1961 GMC Suburban
Old 05-31-2015, 06:16 PM   #19
thumpros@yahoo.com
Roger that!
Old 05-31-2015, 08:06 PM   #20
jtrichard
I am putting 17'S on (front) of my 63 with 1" spacer and if you have the alloy wheels look for (GM dual lug nut) or (bulge lug nut) if you dont have/want the plastic caps..... you will need to know what thread the studs are on the spacer assuming you cant find a spacer with the lug nuts you want (EBAY is where i found mine)
jtrichard is offline   Reply With Quote
Old 05-31-2015, 08:22 PM   #21
thumpros@yahoo.com
jtrichard,
Thanks. I'll look at eBay...
