Old 05-01-2008, 07:00 PM   #1
prg machine
prg machine's Avatar
door assembly
what is the order of procedure for assembly of the door parts after it is hung properly.? Window reg first? door latch mechanisms first? Or what?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-02-2008, 03:39 PM   #2
prg machine
Re: door assembly
anyone????
383 .040 over
Old 05-03-2008, 04:28 AM   #3
prg machine
Re: door assembly
ttt
383 .040 over
Old 05-03-2008, 10:49 AM   #4
JimKshortstep4x4
Re: door assembly
This is the order of installation that I use:
-Door latch, including rods and actuator
-Window regulator
-Rear window track (left loose so it can be moved until everything is in place)
-Window
-Vent window assembly
-Window seal
-Window fuzzies
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-03-2008, 06:48 PM   #5
prg machine
Re: door assembly
Thanks a million. That is exactly the info that i was looking for!!!!!!!!!!!!
383 .040 over
