Old 11-03-2002, 10:21 PM   #1
bigblock73
yeller
bigblock73's Avatar
what is your next modification?
Thought it would be kind of neat to hear what you all have planned next for your truck...what is the next item you are going to purchase, what is the next modification, etc...
Right now my cab is getting some welding done to it (smooth firewall), and after that the cab will be getting re-painted and put back on the frame where it belongs!
I told you mine, lets hear from you!
-Jeff
bigblock73 is offline   Reply With Quote
Old 11-03-2002, 10:26 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I guess mine's finishing my speaker box and console. I am mostly done except for getting everything covered. Still a few small things left to do before taking them to the upholstery shop. Then I'll get my MegaShifter installed and hooked up.
Can't seem to get motivated lately. Too much junk going on.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-03-2002, 10:31 PM   #3
ocbaud
Garage Queen Material
dropping it!!
ocbaud is offline   Reply With Quote
Old 11-03-2002, 10:42 PM   #4
Silveradoshorty
Interior, then drop 3/4
Silveradoshorty is offline   Reply With Quote
Old 11-03-2002, 11:15 PM   #5
78SilveradoSWB
78SilveradoSWB's Avatar
Talking
The next modification is the suspension, which will involve installing my newly acquired Hellwig rear anti-sway bar, C30 front sway bar, lowering 3/5 or 4/6. Still need to get 3+1 leafs and 1 inch front springs, Edelbrock IAS shocks. Already have 5" flip kit and 3" DJM spindle. Still deciding between 1" block or use of a 2" shackle. After that I will work on the interior.
78SilveradoSWB is offline   Reply With Quote
Old 11-03-2002, 11:43 PM   #6
Tom
driving is in my blood
Tom's Avatar
Well, Im in the middle of the 2004R swap right now. After that comes the new front clip. Then the whole truck sanded and primerd. Then tires so I can install the drop kit [5/6] sitting in the back yard. After that Im getting a cowl hood. Somewhere in all this will come a 3/4ton or 1ton front sway bar. Rear sway bar is a bad idea on trucks unless you never push them all the way, so Im not getting one [I DO plan on pushing it HARD threw the corners]
Old 11-03-2002, 11:55 PM   #7
messed up c-10
RHCP afficianado
messed up c-10's Avatar
putting my new wheels on. Boy that sounds weird. I didnt think I was ever gonna get anything big for my truck. Also getting a cowl hood.
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 11-04-2002, 12:05 AM   #8
TX_Mudder
I need a paint job something fierce.
-- Mike
TX_Mudder is offline   Reply With Quote
Old 11-04-2002, 01:41 AM   #9
low 84
low 84's Avatar
i'm putting buckets and a megashifter in in a few weeks. then in december putting the iron eagles on it. after that it will be awhile, b/c i plan on taking advantage in working at sears and buying a 3 stack tool box and filling it with tools at almost half price. then i'll be getting gears (3.55 probly). and a 408 sbc is in the works as well.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 11-04-2002, 01:42 AM   #10
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I need a front end rebuild and some dress up goodies for under the hood. Alt. bracket, Ram air box, aluminum valve covers just to start
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 11-04-2002, 02:11 AM   #11
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
my next mod or mods
1:new body parts and primering
2:3/4 ton springs
3:clean up the interior
4:fix up motor for more horsepower and dress it up a little
5: other little rountine maintenance stuff
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 11-04-2002, 10:18 AM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Suburban front suspension swap with 1.5 lowered coils. I already have the 91 grill swap.
Then the 350 crate killa!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-04-2002, 11:08 AM   #13
BigRed
If I can find a fairly good intake at the swap meet, that will be the first thing.
My floorboards are getting fixed. Got some rust problems. Will be getting some POR15 and some sheet metal to patch in. Then, will cover with carpet.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 11-04-2002, 11:40 AM   #14
bigd65
bigd65's Avatar
well i think my next is to replace the poly bushings on the control arms. then 1 in drop springs for front, that will be all the drop i will put (already have the 2in drop shackles on) then i am going to start the body work. i have a few places that are popping up rust, so i think i am going to fix all this stuff real good before the paint job ( grey, of coarse, with 2 1ft wide stripes ,approx 2-3 shades darker grey that run from the front across the top and down the tail gate and then bed liner coating) then maybe tires, tires maybe first, or during the body work, yep thats it, during the body work
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 11-07-2002, 10:43 PM   #15
Razorback_Fan
Razorback_Fan's Avatar
Well currently its in the paint shop getting painted Dark Charcoal Grey with a metallic flake, this is a list of things that will be done when it gets out (Suppose to be finished the week of the 18th :=)
Front and rear Pans
Tailgate Skin
Handle Relocator
Side Markers Shaved
Mirrors Shaved (Can't Find any aftermarket ones that look cool)
Drip Rail Shaved
New Phantom Billet grille
Headlight Conversion Kit
New Glass/Gaskets/chrome trim and Tint
Got my shipment in from Eastwood today so if I ever get her out I'll start changing the interior over from blue to black.
Razorback_Fan is offline   Reply With Quote
Old 11-08-2002, 01:06 AM   #16
TX_Mudder
On the short list:
1. Gearswap rear out to 4.10
2. Install new instrument cluster
3. Swap front axle yoke to 1350 (4x4)
4. Install SS braided brake lines on my rear discs.
Have all the parts in the garage, just waiting on me to actually go do it.
-- Mike
Old 11-08-2002, 02:07 AM   #17
87gmc
I Got My Engine!!!!!
87gmc's Avatar
Mine would be to get all the parts that i just spent all my money on installed.
F.O.R.D.
"F*cked Over Rebuilt Dodge"
-+-+-+-+Cameron+-+-+-+-
1987 GMC HIGH SIERRA LWB 1500
32X11.50
383 TBI/Vortec Heads/Intake
MSD Ignition
Dual Exhaust
Custom Pinstriping
Sweet interior & stereo
http://www.cgalvin29.freehomepage.com
87gmc is offline   Reply With Quote
