Old 05-01-2008, 10:14 PM   #1
70STOVEBOLT
70STOVEBOLT's Avatar
Heater motor cable
What is the purpose of the cable that is attached to the heater motor switch?
I turned it on yesterday morning and I heard a pop and the lever moved really easily, but the switch still turned the motor on and off like normal.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-01-2008, 11:23 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Heater motor cable
to open the vent. When you shut it off, the door cets closed. the first 1/2 of the range of motion on that switch is to open the vent door and just let air through the heater core if you just want a bit of air but don't need the blower.
Old 05-02-2008, 02:08 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You have probably popped the lever.It was originally made of pot metal.The vendors will carry a kit to repair it.takes a couple of hours with time for repaint to dry to repair it.The kit uses steel levers so it will not happen again.You may want to remove the heater cables and clean them up in solvent or something, then lube them.I clamped one end in a vise and worked the outer sheath back and forth to loosen it up.Then I tossed them in an oil drain pan for a couple of days,with oil in it.It's been 6-7 years and they still work great.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-02-2008, 04:56 PM   #4
70STOVEBOLT
Ok, thanks guys. I figured the cable just popped off the lever, but it may be the lever, I haven't looked at it yet. Seems to be getting the same amount of heat as before.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
