Old 11-03-2002, 10:41 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
auto column help
converted 72 over to auto on column.everything is correct for the 72.it changes real smooth except pullin from park to rev or netural to rev/park you almost have to force it.you can go from
n/d/l2/l1 and back to neutral real easy just not to rev/park.please help
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 11-03-2002, 10:49 PM   #2
mrein3
mrein3's Avatar
I made the same switch about a year ago and since then I've had the same problem. If it is a detent to get into and out of Park it sure is a good one.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-03-2002, 11:18 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've never seen one shift smoothly from park.
On the Longhorn, I removed the colar from the column, and coated it with anti-seize after a real good cleaning. Id still don't feel 'right', but you don't feel like the shifter wil pop off and bust you knee cap anymore.
Old 11-04-2002, 01:36 AM   #4
68 Stepside
huh?
68 Stepside's Avatar
Mine was converted to an auto column by the PMO (Previous Moron Owner), and it's extremely easy to move through the gears. Then again, it doesn't lock into park extremely hard either...so maybe he left something out when he put the column in.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-04-2002, 01:39 AM   #5
72shadetree
KEEP ON TRUCKING
thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 11-04-2002, 02:00 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Well, you could always do the the PMO of my truck did to make it shift in and out of park easier......shove a piece of # 9 wire behind the tab so it can't fall into place.....I took the wire out now it shifts in and out of park hard.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
