Old 05-02-2008, 12:55 AM   #1
HoupPhotography
Wheel Question
I have 20" wheels with 50 series tires on my truck now, how much will the truck drop when I put a 15" wheel on with a 4" white wall (I don't know what sidewall heighth those have)
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-02-2008, 02:18 AM   #2
Re: Wheel Question
Use this and put in the size tire you currently have and then the new size or sizes you want to run. Figure the difference in height and 1/2 the difference of the two is how much drop you'll see. Again, this is approximately
http://www.1010tires.com/TireSizeCalculator.asp
Example
255/50x20 = 30" tall
255/70x15 = 29" tall
235/75x15 = 28.9" tall
265/70x17 = 31.6" tall
275/55x20 = 31.9 " tall
So going from a 20 to a 15 you might only drop a 1/2"depending on the size/profile tire.
Palf70Step is online now   Reply With Quote
Old 05-02-2008, 05:07 AM   #3
HoupPhotography
Re: Wheel Question
I'm going from a 275\55R\20 to a 215\70R15 my truck will drop about 5inches.... am I reading that right?
The overall diameter is going from 31.90 to 26.85
Old 05-02-2008, 05:30 AM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Wheel Question
Originally Posted by HoupPhotography View Post
I'm going from a 27555R20 to a 21570R15 my truck will drop about 5inches.... am I reading that right?
No, it will be a 2.525" drop because you have to divide the diameter by 2 to get the distance from the center of the hub to the ground.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
