Old 05-02-2008, 04:01 AM   #1
RaceAGMC
RaceAGMC's Avatar
TH350 Not going into gear
Ok guys, i'm new here, been kinda lurking around for a few months, but just picked up my 70 SWB truck, its a 350 with i believe a TH350 trans. I just got the motor running last night, and i go to put it in gear and the shifter moves, i hear the linkage moving at the trans, but no matter where i have the shifter, nothing happens. Any ideas? I sure would like to get this thing moving on it's own power.
RaceAGMC is offline   Reply With Quote
Old 05-02-2008, 04:04 AM   #2
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Re: TH350 Not going into gear
Could be anything internal with the trans. Converter could be mucked up, pump gear might be stripped, filter might be cloged all together.
How new is the trans?? any info on it?? might not have a drive shaft installed???! *lol, jk*
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-02-2008, 04:06 AM   #3
racin69z
racin69z's Avatar
Make sure it's full of fluid before you try anything else.
Sometimes th350's have a good bit of delay before they kick into gear when they cold/been sitting for a while. It helps to blip the throttle up to about 1500-1800 rpm once or twice.
If you don't know the history of the trans, you can pull the pan and check the filter. Other than that, I would think you need to have it torn down to see whats wrong.
racin69z is offline   Reply With Quote
Old 05-02-2008, 04:08 AM   #4
RaceAGMC
RaceAGMC's Avatar
I have absolutley no history on the trans other than the guy that sold me the truck said it was new, but i know the truck has been sitting for at lease 4 yrs.
Old 05-02-2008, 04:11 AM   #5
jayharrell
jayharrell's Avatar
I agree, drop the pan. The only thing about that is you need 7 or 8 *can't remember how many it takes* quarts to get it back. So about $45 with the filter and fluild just to check the filter. It might just clean itself out with a fluid change.
Check and make sure all the trany bolts are tight and the trany is flush to the motor. The bolt holes in the trany will wear a V in them and with out washer it'll pull loose and strip the pump gear or worse break a fly wheel *ask me how i know, lol* There had to be a reason the PO stoped driving it.
00 S10 2.2 Vin5
Old 05-02-2008, 04:16 AM   #6
RaceAGMC
RaceAGMC's Avatar
Jayharrell, i'm sorry i'm new, what is the PO?
Old 05-02-2008, 04:17 AM   #7
Olden Days
Living In The Past
Olden Days's Avatar
In 4 years time it may have all leaked out (fluid) check the fluid level.
Olden Days is offline   Reply With Quote
Old 05-02-2008, 04:34 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
PO is previouse owner.
I would crawl under, and make sure the converter is bolted to the flywheel, and then check the fluid level.
If it still doesn't move, probably plan on dropping the tranny out.
Old 05-02-2008, 04:43 AM   #9
RaceAGMC
RaceAGMC's Avatar
I'm actually not sure if the PO ever drove it with this Engine/ trans combo in it, he swapped or had someone swap a newer crate motor in it...sort of. When i picked it up it did not run, it needed some small odds and ends to get it fired up. I got it running, now i can't get it to move, I'll check the fluid tomorrow and keep u guys posted, btw, how many qts should it take if it is empty? I hope it isn't empty though.
BTW, thanks for all the quick replies.
Old 05-02-2008, 04:46 AM   #10
CharlieBrown
CharlieBrown's Avatar
as a guess
front pump could be bad..if so you have park..and5 neutrals basically
pull a cooler line off the radiator..start it up and see if there is pressure
if none...suspect pump
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 05-02-2008, 04:53 AM   #11
Longhorn Man
if the engine was 'just dropped in' that gives you even more hope of the converter bolts being out.
Old 05-02-2008, 04:59 AM   #12
jayharrell
jayharrell's Avatar
It would have made a realy realy bad screaming noise just for a few seconds right after the first start if the convertor wan't locked in right when the tray was bolted up. That points to the pump being bad. And the noise was the pump gear tabs shreading. It sounds almost like a started sticking for a second or two.
But i'm on par with everyone else too. Check flywheel bolts and see if the cooler line is pumpingout fluid while running.
00 S10 2.2 Vin5
Old 05-02-2008, 05:17 AM   #13
Longhorn Man
if the converter is pushed back, then there would be no noise at all, the converter won't spin with the flex plate. If the converter was pulled out, then it would clang like no one's buisness and he'd be scared that it has a rod knocking.
Old 05-03-2008, 05:58 AM   #14
RaceAGMC
RaceAGMC's Avatar
Update: It was just super low on fluid. I dumped quite a bit in, and booyeah, she moves! Thanks for all your replies. I'll keep you updated on the progress as I get her roadworthy.
