starter lag
i recently installed a remote solenoid and now there is a lag when starting the truck. not everytime, maybe about half of the time. why is that? what is the fix for it?
1972 Chevy C10 Long Bed 454 Big Block Turbo 400 3 Speed Dual Flowmaster Edelbrock 750 Carb Power Steering Disc front brakes Drum rear brakes B&M Floor Shifter |
Re: starter lag
Define "lag".
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Re: starter lag
to delay or fail in reaching full development
when i turn the key, instead of turning over right away, there is a pause or a slow response to the starter. almost like when you try to start the truck with a weak battery. it does start, just not instanly. battery is brand new and with high cold crank amps.
Between Trucks...
Re: starter lag
Check your ground...
Beat it to fit, Paint it to match... ![]() |
Re: starter lag
disconnect clean and reinstall ground
Gettin By on Gettin By
Re: starter lag
x3, ground.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
Re: starter lag
Cable size?
To The Levy
Re: starter lag
have you tried bypassing your auxillary sw. run your purple or solenoid wire directly to "S" term. on starter and see if your hesitation or Lag still there.
what about if you run a jumper straight off the main term. of starter and the S term. of starter is there lag , if so I would wonder cond. of starter, but sounds like something ahead of that... |
Re: starter lag
cable size should be good. battery cables to battery and to b terminal on original solenoid. as for the wire from the s terminal, i believe it's 10 or 12 gauge. i will check the ground and the purple wire connection. thanks guys.
