Luv the Crewcabs
Pwr. Steering Pump & Brkt's 250 6 Cyl.....
Pump & Brkts came off a Running 250 6 Cyl. in a 81 Chevy truck
$ 85.00 Shipped to USA Respond in Post Thanks, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
Luv the Crewcabs
Re: Pwr. Steering Pump & Brkt's 250 6 Cyl.....
ttt
Active Member
I will take if it bolts up to a 68 Inline 6 250
Luv the Crewcabs
Steve,
If your Motor is the Original , This is not a Direct Bolt up for it. This set-up is for the Intergrated Head 6 that was on Later Trucks........... With that said, I did use a Set up like this on my Wrecker that has the old style 6 in it, I Notched the Back of the Bracket to Clear the Exhaust & Used a Bracket i had from a Camaro that i had laying around, I will attach some pics of how i did it for the Wrecker. Thanks, Rick
Luv the Crewcabs
In this Pic I marked the Area i Cut away & Used thie Bracket to mount it to the Frame, That took the place of the Bracket that is kind of angled & Mounted to Back of Pump & Then Lower on The Engine Block...................
The Yellow Lines are the Brkt i Used & Show the Area i Cut out, Sorry my Paint Skill is Lacking ![]() ![]() ![]() Thanks, Rick
Luv the Crewcabs
ttt
