ok well now im down to this. i replaced the coolant sensor and all the spark plugs and wires to it. now i still have a miss fire on cylinder one which is the fuel injector. i already bought the injector and am ready to switch it out. i have a V6 engine and it seems that the injectors are underneath a plastic case. i dont see no outside fuel rails. how hard are these to switch out,. i just need to replace one only., any help or advice will be great .
Re: replacing fuel injectors on 02 silverado
alright. i replaced the bad injector within two hours. it was a cake walk. the hardest part was keeping up with where each nut and bolt went. now i ran into another problem . my check engine light came off but my factory cd player will not turn on,. i left the battery disconnected while i replaced the injector . now the cd player dont play,. any ideas on how to turn on the music again. im bored driving with nothing to listen to..
I miss this truck.
I would suppose that googling " '02 Silverado Radio reset" or something of that nature would get the info you are looking for. I know on my 2000 Malibu, that's how I figured out how to reset the stereo.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
chrome makes it go FASTER!
Question-- How did you find out which injector was faulty?
I'm having a problem with my '00 that might be a bad injector. I don't want to replace all to find bad one.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
Well i got a friend that owns a shop so he just hooked up a diagnostic scanner to it and it told me exactly which one it was. Actually it had two bad injectors.. he told me to put some B-12 injector cleaner and some 104 fuel treatment in the gas tank. you can find this at autozone or oreily autoparts stores. .. i put both on a quarter of a empty tank and it clean only one. Good luck.. Its not that hard to do . it was my first time and it was ok ..
![]() Join Date: Jan 2003
If you have it, check your owners manual for the CD player. When the batt is disconnected the radio will need a securty code to start working again. If you don't know the code, take it to the dealer. The last time I had to deal with this, the guy in the parts dept came out and did it for free.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
#7 | |
On the fast track to nowhere..
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
![]() Join Date: Sep 2005
easy way tell which injector is not fire would be to . 1 pull a plug wire off one at a time until u get the the cylinder that it doesn't make a difference in how it runs or do the same thing with the injector wires. or if you have a miss have the codes pulled
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
