Old 05-04-2008, 03:39 AM   #1
Riveted1
Tasty Cakes!
Riveted1's Avatar
Modified rear fenders?
Was looking for threads on modifying the rear fenders on bagged trucks. I remember seeing at least one somewhere. I did a search but must be using the wrong keywords. Can someone hook me up? Or can you post info on what you've done to your rear fenders to get those big wheels tucked up inside??
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-04-2008, 07:53 PM   #2
70short
Re: Modified rear fenders?
I bought 2 pair and made 1 pair 6" wider. They go to the frame. I also removed the factory bump stops and brackets. I am planning on a c-notch they will have the bumpers.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 05-04-2008, 10:17 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
Those look good!
I'd like to see how people altered their steel bed floors as well, because once u start extending those fenders, you end up on the ridges of the floor. (Don't you?) So I'd like to see some pics of that.
I know there was a build somewhere that had this done. No one has that bookmarked?
Old 05-04-2008, 11:21 PM   #4
SCOTI
SCOTI's Avatar
Originally Posted by Riveted1 View Post
Those look good!
You cut the 'ridges' (the raised runner of the bed floor) across the ridge about .500" longer than where you need them to bend down to the flat portion of the floor.
To make the bends, scribe a line where you want the bend to start, drill .0625" holes every .125" on the scribed line. Once the holes are drilled, gently tap the end of the metal down (you don't want to cave it in so don't be too aggressive).
Now the other side of the runner will need to be 'flattened' to be the same height of the flat portion of the floor. You can cut it out & replace it w/a flat piece of sheetmetal, or you can make a cut down the center of the runner & hammer the two sides together until they are flat & touch each other (leave enough gap to properly weld the seam solid).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-05-2008, 01:47 AM   #5
Riveted1
Tasty Cakes!
Riveted1's Avatar
Great info there Scoti! That's exactly what I needed. I'm a noob at all this stuff, but I'm building lots of files and gonna take my time doing it.
Wasn't there also a post about cutting out the section between the outer panel and the fender well to get some more room?
Old 05-05-2008, 03:03 AM   #6
Slammed70
Slammed70's Avatar
Now lets see the meats your gonna tuck under there.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 05-05-2008, 03:35 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Heres the inner bed mod...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-05-2008, 10:32 AM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
You got a link to that thread Frenchy? <---- Sorry, I couldn't resist!
Old 05-05-2008, 07:10 PM   #9
SCOTI
SCOTI's Avatar
Here's the link. . ..... http://67-72chevytrucks.com/vboard/s...d.php?t=184474 . Unfortunately, some of the pics dissappeared a while back & have yet to be restored on the site.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-05-2008, 08:34 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
No biggie thats what I usually go by on here have for years..
MEMBER #6377
Project "7DEUCE"
Old 05-05-2008, 09:52 PM   #11
Riveted1
Tasty Cakes!
Riveted1's Avatar
Thanks Scoti, that was the one I was thinking of. Still one of my favorite trucks of all time. I saved the pics from this thread for reference. Too bad most of the other pics are gone. That could have been a step-by-step guide for me (for my whole truck), but a lot gets lost in the translation w/out the pics...
