Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-04-2008, 07:03 AM   #1
1970chevy
timing
just fired up the beast and its popping at around 5000 rpm. im running a 1000cfm dominator, its burning rich...does anyone know what size of jet i should run?? what should the timing be for a 515 big block chevy??
1970chevy is offline   Reply With Quote
Old 05-04-2008, 06:03 PM   #2
djracer
djracer's Avatar
Re: timing
sweet looking truck! I am running my total timing at 34 but I am gonna try 38 and see if it speeds up or slows down!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-04-2008, 06:09 PM   #3
bigjimzlll
bigjimzlll's Avatar
Re: timing
I run any where from 36-40 degrees. 92 jets on my 1150. 8lbs of fuel pressure. (165 jets on my 1050 alky dom)Which ignition are you running? Are you sure it's not a rev limiter kicking in?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 05-05-2008, 03:21 AM   #4
1970chevy
Re: timing
not sure just running a msd hei distributor i got no ignition up grade yet just order a msd digital 7 box
